ASUS VW161D  Monitor
Take a brief Survey Take a brief Survey   Add to My Products Add
Problems with ASUS VW161D Monitor?
Troubleshooting and Support
Solved Problems for ASUS VW161D  Monitor RSS Feed Post a New Problem
RE FPD1960 power issue
Hi I have no problem sending it to you but can you give me a quote? Thanks azucho98 Hi, I'm in the middle of moving so...
1 Solution
Gateway FPD 1830 LCD Monitor
When power applied, display briefly comes on -- then blanks off. Power light remains on.
1 Solution
samsung crt 591s blank problem
this monitor haven't be use for 2 month ago. before that, this monitor working normally. but today, i start up my pc,...
1 Solution
Output to Monitor and Keyboard.
You have replied me that Power Supply is dead. but Mouse is getting the power supply and Monitor is also getting the...
1 Solution
faint white spots on macbook pro lcd...
Dear experts, I own a macbook pro 1.83 GHz Intel (one of the first releases - year 2006) and I recently noticed some...
1 Solution
Dell 15 inch monitor, brightness/contrast...
The display for brightness/contrast remains on the screen, at times cycling through the EXIT, BRIGHTNESS, CONTRAST...
1 Solution
Monitor Resolution Using Adobe Illustrator
I switched my monitor from a Sony 20in normal flatscreen to a 19 inch LG W1942T widescreen. When I am using Adobe...
1 Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Product MPN
MPNVW161D
Key Features
Viewable Picture Size16 in
Contrast Ratio 2,000:1
Brightness 250 cd/mē
Monitor Type Widescreen LCD
Dot Pitch 0.252 mm
Aspect Ratio 4:3 · 16:9
Response Time 8 ms
Color Depth 24-bit (16.7M colors)
Technical Features
Form FactorDesktop
Regulatory ApprovalBSMI · CE · UL · cUL · C-Tick · MIC · VCCI · CB · ISO 13406-2 (Pixel defect guidelines) · Energy star · FCC · TCO-03 · PSB · GOST-R · CCC · RoHS
Synchronization Range - Horizontal30 - 82 kHz
Max. Viewing Angle - Horizontal90
Max. Viewing Angle - Vertical65
Native (Recommended) Resolution1366 x 768
Synchronization Range - Vertical56 - 76 Hz
Supported Models
Black
ASUS Contact Information
Main support number502-995-0883 (select option 3)
Support FAX502-933-8713
Sponsored Links
Loading problems.
Top Monitor Experts
CosmaP
1 solutions
Modems, Software, Computer Hardware, Storage and Media,...
Ask Me
Guru
lickwish
2 solutions
Cars, Cellular Phones, MP3 and Digital Media Players...
Ask Me
Guru
freetek
7 solutions
Ask Me
Wiz
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
