20 Most Recent
Panasonic HDC-HS9 HDD Camcorder Questions & Answers
I need a driver for
If you're in the US, contact Panasonic's National Parts Center at
800-833-9626 between the hours of 9am and 7:30pm EST Monday through Friday to request a replacement software CD.
If you're not in the US, go to http://panasonic.net, select your country or region, and go from there to contact Panasonic.
7/2/2011 6:54:43 PM •
Panasonic...
Answered
on Jul 02, 2011
Taking the hard drive out of a HDD camcorder
If the hard drive is build in inside the camcorder removing the hard drive will void any warranty it may have.
To remove the internal hard drive you must disassemble the camcorder. This is very straight forward process. You remove all the screws from the camcorder and check for any hidden screws under soft objects and labels, then the casing / cover will be held in place with plastic clips, you go around the cracks of the case with your fingernails or a plastic stick to release them a flat screw driver can also be used.
You have to take apart the camcorder as much as you need to get to the hard drive and remove it, then assemble the unit back together.
This will void any warranty that the camcorder might have.
11/27/2010 9:28:33 PM •
Panasonic...
Answered
on Nov 27, 2010
How can I get AC
I have the same problem, and its a lot of cargers out there so you can carge your battery. Problem is when you would like to uploade your films to your computer, then you have to use DC in. And thats just the orginal charger who has that.
Have you found your cabels?
11/25/2010 7:41:04 PM •
Panasonic...
Answered
on Nov 25, 2010
I am looking for a
You can download and print the instruction manual for Panasonic HDC-HS60 in PDF format by clicking this
link.
Adobe PDF Reader is required to view this manual.
Click here to download the latest version of Adobe Reader.
Thanks for using
FixYa.
10/3/2010 12:34:44 PM •
Panasonic...
Answered
on Oct 03, 2010
Need users manual for panasonic
You can download and print the instruction manual in PDF format by clicking this
link.
Hope this helps. Thanks for using
FixYa.
9/26/2010 6:28:22 AM •
Panasonic...
Answered
on Sep 26, 2010
