20 Most Recent Speed Queen SWT921 Top Load Washer Questions & Answers
Speen Queen washer won't start
Count the number flash,s before a pause. This is the error code
10/31/2018 6:29:53 AM • Speed Queen... • Answered on Oct 31, 2018
Washer motor overheating
Check the drum for ease of rotation, bearing noise. Make sure all support springs are good and at the same position.
11/28/2013 3:11:36 AM • Speed Queen... • Answered on Nov 28, 2013
Coin-operated Speed Queen washer: Model swtt21wn
speed queen double front load washer spinning without stop,please give some idea,thanks alot
1/7/2013 10:40:48 PM • Speed Queen... • Answered on Jan 07, 2013
Speedqueen commercial washer m# SWT021WN will not
I have the same problem... how did you fix this issue?
7/25/2012 3:58:10 AM • Speed Queen... • Answered on Jul 25, 2012
0answers
White residue on clothes
Common usage things to check:
  1. Detergent formulation
    Make sure you're using high quality detergent that contains both sodium carbonate and aluminosilicates. They'll be listed on the ingredient list.
  2. Amount of detergent
    The detergent amounts given on the usage label of the detergent box are for average water hardness (4-9 gpg). If your water is harder than average, or if your clothes are really dirty, you'll need to use slightly more detergent than what's recommended on the box. If you have really hard water, you may need to add a packaged water conditioner to each load, such as CalgonĀ® or Spring RainĀ®.
    If your water is softer than normal, you'll create too many suds, which will retain gookus. In this case, you'd use slightly less detergent than recommended on the box.
  3. Cold water washing
    If you wash clothes in cold water only, the cold water should be in the range of 65-75F. If it's too cold for your hands to comfortably be in the water, it's too cold to activate the detergent.
  4. Overloading
    After the washer is loaded with clothes and then filled with water, there needs to be enough head room in the tub for the clothes to swish around in. A properly loaded washer has clothes loosely placed in the tub up to the top row of holes.
  5. Rinse-added fabric softener
    Some fabric softeners and detergents have a chemical reaction that can create white deposits (also called 'gookus') on the clothes. Try switching brands of fabric softeners or detergents or not using fabric softener at all for a couple of loads.
12/31/2010 4:01:26 PM • Speed Queen... • Answered on Dec 31, 2010
0answers
Very slow fill on rinse cycle.
Clean out filter in the fill valve by removing the inlet hose at the machine end and pulling out and cleaning the plastic filter
4/1/2010 9:17:35 PM • Speed Queen... • Answered on Apr 01, 2010
Speed Queen Model SWT220WA 3/4 filled with water,
motor stalled
take off the belt and see if it will run
if it wont run could be timer or motor
if it runs cold be a stuck gearbox
8/29/2009 4:40:56 AM • Speed Queen... • Answered on Aug 29, 2009
2answers
I'm looking for purchase speed queen washer Model LWS17NW3022 drive Motor, with cheap price if it's available.
Are You postive the motor is bad . Have you checked if it is geting power to the motor or does the motor hum when trying to start .
11/11/2023 5:36:33 PM • Speed Queen... • Answered on Nov 11, 2023
Speed Queen Washer. I need a wiring diagram for it please?
Question edited for clarity and toss in some CAPS. Duplicate question deleted. Refresh page to see your question. Here is the Service Manual with wiring diagrams. It helps to have model numbers in questions like this as 'Speed Queen' is a range. https://www.groupdynamics-laundry.com/mans_files/5/36793.pdf ..
8/26/2023 4:35:07 PM • Speed Queen... • Answered on Aug 26, 2023
2answers
Speed queen washer shown er65
The Speed Queen error code 65 occurs when the washer's main control board detects a problem with the door switch. The door switch is a safety feature that prevents the washer from operating when the door is open. When the main control board detects an issue with the door switch, it will display the error code 65. There are a few reasons why the door switch may be malfunctioning. The most common reason is that the door switch is dirty or obstructed. Another possibility is that the door switch is loose or damaged. If the door switch is damaged, it will need to be replaced.
5/25/2023 3:28:11 PM • Speed Queen... • Answered on May 25, 2023
Speed Queen Washer displaying codes TL 05. 00 D5
Yes, good diagnostics and summary. Don't guess with control boards for exactly the reason you stated. Call for service, you need the correct diagnosis and warranty on the part and the service call. There are indeed expensive and not for guessing.
3/16/2023 5:20:03 AM • Speed Queen... • Answered on Mar 16, 2023
2answers
Speed Queen Washer AWNE92. Agitate runs full speed on delicate cycles. Have tried unplugging and such. Any ideas?
Speed Queen AWN542 using the delicate cycle. Provides a brief wash, 3 minute pause, quick agitation, then slow speed spin drain. https://www.youtube.com/watch?v=VRyowST7tYo
2/27/2023 11:30:22 PM • Speed Queen... • Answered on Feb 27, 2023
Speed Queen SC30BC front load single phase 240 volts washer.
To diagnose the issue with the Speed Queen SC30BC washer, it's important to determine which component is causing the fuse to blow. Here are a few steps you can take to help identify the problem:
  1. Unplug the washer and visually inspect the wiring and components for any signs of damage, such as frayed wires or melted components.
  2. Check for any loose connections, and tighten them if necessary.
  3. Use a multimeter to measure the resistance across the wiring and components. If the resistance is very low, it may indicate a short circuit.
  4. Check the drain pump for any blockages or damage.
  5. Inspect the control board for any signs of damage or melted components.
  6. Test the door switch to make sure it is functioning properly.
  7. Test the water level control valve to make sure it is not stuck open and allowing excessive water into the washer.
If you are not comfortable with electrical repairs, it's best to call a professional for assistance. Attempting to repair electrical equipment without proper training can be dangerous and potentially damaging to the machine.
2/13/2023 5:55:19 AM • Speed Queen... • Answered on Feb 13, 2023
Speed Queen top loader leaks water from the top during washing water spills from top of outer tub ring.
Is it overfilling, too close to the top? If so, replace the water level sensor. Some have an adjustment screw in the centre.
1/13/2023 5:33:56 PM • Speed Queen... • Answered on Jan 13, 2023
Speed Queen SWT921 Top Load Washer Logo
23 questions posted
Top Speed Queen Washing Machines Experts
Paul Bade
NOEL
NOEL
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Speed Queen Washing Machines
Most Popular Question
very slow fill rinse cycle
  • Washing Machines
