20 Most Recent
Samsung LA40A450 40 in. LCD TV Questions & Answers
Will a Samsung 40" - 42" HD TV hook up and work
I haven't had any issues reported to me regarding any incompatibilites with samsung TVs. Also our equipment is compatible with almost any TV so my bet would be that it's compatible, you may check Samsung's website as well.
Daniel Busa
DISH Network
Customer Service
When I switch on my
This problems could be also causes by the board the call the T-CON docoders board,it sit in at middle of the bottom of the LCD screen panel.Because this board decoders incomming pictture signal before it go into the LCD screen panel to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoderd board for the replacement.
My Samsung LCD TV (40A450) 40 inch, when switch
The capitors on the back might be bad this I have fixed on these tv's many times. That could be one of the problems and the capitors are on the power board inside the tv. If you do not know how to work on electronics I would have a pro do it they contain hight voltage so be careful if you try to fix it yourself.thanks
LA40A450CI no baclight
Check and replace damaged component/s at its
back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the inverter board as card basis.
My samsung LE40A656A1F has white horizontal lines through it?
FixYa expert monitors advised me to not give people this advice, but I am a TV repair specialist with pretty solid experience in LCD and plasma TVs and there is only one good advice I can give for those cases.So I am a bit in a conflict here as the website managers asked me not to tell people what I know is the best.So I won't.I am not telling you to replace the TV and I am NOT telling you to not waste time trying to fix this.There...I didn't say it!BTW the hiding and re-appearance of the line(s) had really nothing to do with the cable at the back; it had more to do with you applying physical pressure to the TV frame, something that may yield some result even now, but it can't be used to successfuly restore functionality in long run.
La40f7 LCD Samsung tv no sound
Do you have video? Start with making sure the "Mute" feature isn't turned on. Also check the menu, some sets give you the option to turn off the internal audio !!!
No Sound on a la40f7 LCD samsung
Check its speaker/s first. If found OK, check and replace damaged component/s at its audio output section circuit. If
you wish to get some details, check this link.
http://electronicshelponline.blogspot.com/ Selecting the view option, either to
Mosaic / Timeslide / Flipcard, can be
selected by the
drop-down list, at the top left of the display window,
will make surf easy. You can also do a
search, by type in the
brand name / model number / IC used, in the
search box at the top right of the display window.
