20 Most Recent
ASUS EEE PC 901 Notebook Questions & Answers
I need to hide the fact i was snooping through my partners asus eee 901
What history are you talking about.
Are you talking about web browser history then in chrome simply press ctrl+h and history comes.Click on clear browsing history and it's done.
In firefox press Ctrl+h and history will be shown on left hand side and right click on which day history you want to delete and option will come simply click delete and it's done.
If you are asking for any-other history please add comment.
I have a asus eeepc901sd with 1gb sdram; want to
Yes but please make sure you know what kind of RAM you need. (ie. DDR1, or DDR2)
Almost all laptops have atleast two RAM ports located on the back. I would advise contacting a licensed retailer to match up the RAM you need and give you a quote. Most laptop DDR2 1Gb of RAM prices around 40$.
Hope this helps ^^, Please don't forget to rate! Thanks :)
HI, I HAVE AN Eeepc 901 and my caps lock goes
sounds like component board/switch failure .If your eeepc is less that 2 years old Asus will collect and repair it for you free of charge.
Also could be "pirate" or non genuine software--its a possibility
Where can i get a new outer casing from as mine is
The best way you will probably find that type of replacement part is through ASUS directly. I would suggest giving their support department a call at 510-739-3777 (09:00-18:00 Mon.~Fri.)
They should be able to provide you with part numbers and costs for the parts you need.
I hope this helps...
Kerry L...
I removed the audio driver by mistake. i have
You need to use ASUS support for this
Is it Linux or windows OS? eithyer way Asus have a good customer support and if the files on their server are indeed corrupt they will want to know and be even more grateful to you for your effort
How do I enhance my Asus PadFone X mini speaker loudness?
Look for a program called Sound Booster or one called DFX. DFX is my favorite because it not only boosts the volume, but lets you add other effects to enhance you sound as well. There is a free version. but to get all the effects you have to upgrade to the paid. If audio is important to you, check it out.
How to fix sound is not working in my asus laptop?
Try going into sound select and test reinstall driver off Asus website..if you installed new windows or update drivers may not work right...see if you can roll back driver in device manager ..if not lookup your laptop model and reinstall...
Graphics card no picture on monitor when connected via HDMI or any cable?
The issue you are experiencing with your graphics card and monitor can be caused by various factors. Here are a few troubleshooting steps you can try to identify and resolve the problem:
1. Check power connections: Ensure that the graphics card has the necessary power connections properly connected. Some higher-end graphics cards require additional power connectors, such as 6-pin or 8-pin PCIe power connectors. Make sure they are firmly plugged in.
2. Verify BIOS settings: Access your motherboard's BIOS settings and check if the primary display output is set to the PCIe slot where your graphics card is installed. It should be set to prioritize the discrete graphics card instead of the integrated graphics (if applicable).
3. Update BIOS and drivers: Visit the Gigabyte website and make sure you have the latest BIOS version installed for your motherboard. Additionally, download and install the latest drivers for your graphics card from the XFX or AMD website. Outdated firmware or drivers can cause compatibility issues.
4. Reset BIOS: Try resetting the BIOS to its default settings. Locate the CMOS battery on your motherboard, remove it for a few minutes, then reinsert it. This action resets the BIOS settings to their defaults and may resolve any conflicting configurations.
5. Check for physical damage: Inspect the graphics card for any physical damage, loose connections, or faulty components. Ensure that it is securely inserted into the PCIe slot and that there are no visible signs of damage on the card or its connectors.
6. Test with a different monitor and cable: Connect your graphics card to a different monitor using a different cable (e.g., DisplayPort, DVI) to rule out potential issues with the HDMI cable or the monitor itself. This helps determine if the problem lies with the graphics card or the specific combination of monitor and cable.
7. Check for motherboard compatibility: Verify that your graphics card is compatible with your motherboard. Check the manufacturer's website for compatibility lists or consult the user manual for your motherboard. In some cases, a BIOS update might be necessary to ensure compatibility.
8. Seek professional assistance: If none of the above steps resolve the issue, it's advisable to contact the technical support of your motherboard or graphics card manufacturer. They may have specific troubleshooting steps or recommend further action, such as warranty service or component replacement.
Remember to handle your hardware with care and take necessary precautions, such as grounding yourself and disconnecting the power supply, before performing any physical checks or adjustments.
I am using an Asus Vivo mini computer approx 5 years old. Since December I often receive error message across top, "Microsoft Edge (not responding)"
Question edited for clarity and toss in a load of CAPS as needed.
Microsoft Edge is one of the worst browsers ever invented. It is flashy and looks pretty, but is not user friendly and is glitchy.
The most likely issue for that Error Message is your Internet Wifi signal dropping out. You can test this theory two ways.
Do you have a smartphone? Download the Free App Speedtest. When you get the Edge Error, whip out your phone and do a Speed Test. If it stalls or only returns a speed of 5 to 10 mbps, that is your issue.
Or Download Google Chrome which is FREE and a much more robust browser and easier to use. Keep both Edge and Chrome open, when Edge collapses, try to do things on Chrome. If Chrome works, then the issue is Edge. If Chrome also fails, the issue is your Wifi and Router. A Router reboot should be done about once a month.
Google Chrome Download - Download Google Chrome
google.comhttps://www.google.com
Continue your browsing experience from desktop to phone on Chrome. Download today. Now more simple, secure, and faster than ever - with help from Google built-in. Google Address Bar. One browser, all devices. Type less with autofill. Chrome support.
Download Now
Get a new and fast web browser. Download Chrome and start browsing.
