20 Most Recent Olympus FE-320 Digital Camera Questions & Answers
Can you give more details ? Is this prior to taking the image, or when you review it afterwards ?
Olympus FE-320... | Answered on Jan 17, 2019
Camera from 2008. Display broken. Needs replacement. Not worth it. Sorry.
Olympus FE-320... | Answered on Jul 05, 2014
Put new batteries in it
Olympus FE-320... | Answered on Mar 31, 2013
Connect your camera or place your memory card into a computer with image processing software to view picture. Or sometimes if you camera is exposed in a high temperature it may affect the lcd display of you camera. Some camera recovers after long exposure to high temperature if place in a cool,normal temperature. Check also your sd card it might be corrupted also.
Olympus FE-320... | Answered on Mar 08, 2013
You directed this question at me, but unfortunately I'm unable to provide you with a "real" solution at this time. FixYa has informed me that by providing you with this "solution" your question will then be made visible to other experts; hopefully one of them will be able to provide you with a real solution.
Thank you for using FixYa.
Olympus FE-320... | Answered on Jan 13, 2012
The display being spotted can be due to failure of the LCD or the CCD which is the optical sensor of the camera. So to confirm check the older picture to be seen on the display. Confirm this by checking the card on your PC. If the display is seen to be spotted, then the LCD can be faulty, fault on the linking cable or the control board.
However if the older images are seen well then the LCD is working correctly and the fault can be failure of the CCD- charge coupled device in the camera. If you have accidently exposed the camera directly to high intensity light / sunlight, then it is possible that it is damaged. Remove the battery and keep the camera aside to reset and try as a last resort. Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Please click on the link for tips to replace a LCD
http://www.youtube.com/watch?v=aB4x7F5Chow
Thank You for using fixya
Olympus FE-320... | Answered on Sep 16, 2011
Return it. It's defective.
Olympus FE-320... | Answered on Sep 10, 2011
Here is the address and contact information of Olympus Authorised Repairer (QLD):
Anderson Camera Repairs
14 Merritt St, Capalaba QLD 4157
Phone: (07) 3245 6444 Fax: (07) 3821 0006
E-mail: admin@andersoncamera.com.au
For location map, click here
Hope this helps. Thaks for using FixYa.
Olympus FE-320... | Answered on Sep 08, 2011
Do you really mean the CCD? That's the imaging sensor inside the camera. If you mean the LCD display on the back of the camera, you can order one at
http://uscamera.com/vg4579usc.htm
Olympus FE-320... | Answered on Sep 03, 2011
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Olympus FE-320... | Answered on Jul 04, 2011
Olympus FE-320 Digital Camera Logo
74 questions posted
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
FE Olympus
  • FE Olympus
Most Popular Question
olympus fe 320 lens wont extend out
  • Cameras
