20 Most Recent
Palm Treo 700wx Smartphone Questions & Answers
My treo 700 wx has low signal strength
First Option:Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved SoSecend Option:Your Phone Network IC Fault So Please change Network ICAnd Network Signal Problem will Solvedif it is there isn't much you can do on this side of the network.Contact your phone company.
I brought my phone from hawaii and i tried to
If the phone is tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the website
Unlock-Zone.com which is doing good service .....you can approach this website.
My palm treo 700wx froze
You tried taking out the battery completely? There is a reset button next to the battery, try holding the button in for 10 to 20 seconds.
How do I send pictures?
HI, you cannot send pictures through text message but through multimedia messages..but before you can do this you need to activate your multimedia messages through your network provider and after activating it, you can only send multimedia messages to people that have also activated there own.
cheers
How do you replace the screen? Is there any
Items you need: a small star bit screw driver, and a flat head screw driver.
Start by taking the back off and the battery out. you will then see 4 screws on the side of the phone. after taking those screws out you will need to take the two hidden screws out. one is underneath your stiles so take that out and you will see it. the next one is underneath a plug just below your antenna (its not the big plug, the smaller of the two) then you will need to take your flat head screw driver and pry around the phone. once you get the housing off of the phoen you should see your board and your LCD (screen) you should be able just to grab the left side of the screen and lightly pull up and to the right. you will see the ribbon go into the screen. remove the tape that is on that. lift the black teeth holding down the ribbon and pull off the screen. To install a new one follow the same steps, just in reverse. you do not need to put tape back on, unless you feel is necesary.
