20 Most Recent
Tascam CD Gt1mkii CD Guitar Trainer Questions & Answers
VERY carefully clean the lens with a QTip and 99% isoprophyl alcohol. Use ONLY 99% and it can be a bit hard to find.
Be careful to NOT snag the QTip cotton on the carriage or parts holding the lens... clean ONLY the lens, very gently. Let dry thouroughly before trying it again.
9/28/2010 6:02:32 AM •
Tascam CD...
Answered
on Sep 28, 2010
Keeps switching off and showing tocread on display
That probably means it can't read the "Table Of Contents" which is essentially the directory of the disc.
MAKE SURE any disc you try to read has been "finalized".
Any disc that you have burned that can have stuff added is NOT finalized and may not work in certain CD players.
5/9/2010 2:52:50 AM •
Tascam CD...
Answered
on May 09, 2010
My tascam cd gt1 does not display anything when
Test the power adapter to make sure that there is power at the plug (volt ohm meter). Try wiggling the plug while it is plugged into the unit with the power switch on. If it works intermittently it means that the solder joint for the power adapter jack has failed on the circuit board. If that isn't the problem it probably is the power switch that needs to be tested next. IF you aren't confident with disassembling the unit far enough to do the tests you will need to take it in for servicing. Let me know how you make out.
1/22/2010 2:37:24 AM •
Tascam CD...
Answered
on Jan 22, 2010
My Tascam CD GT1 mkii guitar trainer is doing
Here is the manual if you don't have one:http://www.tascam.com/details;9,21,23,19.html Make sure your guitar cord is working. Make sure your are plugged into the Guitar/Mike input jack.Do not connect a guitar amp to this jack via line out on the amp or otherwise. Set the Guitar/Mike switch to Guitar. Use the Input control to adjust the level of the input.Adjust your Headphone level using the Output control.Carefully read pages 12, 13, 14 and 15 of the manual.There are various combinations of controls that would make your guitar too quiet to be heard. Example: Mix Balance page 24. Let me know if this helps.
11/29/2009 6:04:25 PM •
Tascam CD...
Answered
on Nov 29, 2009
Every time I try to Export a mastered track it
Several of my music programs seem to have a limit of around 2Gb for a track... this is inspite of having plenty of disk space... this seems to be a limit set by the program rather than the resources available.
12/2/2010 6:12:29 PM •
Tascam Music
Answered
on Dec 02, 2010
What does it mean when u get a service error on a
I recommend contacting Tascam at this link:http://tascam.com/contact/support/ Describe your problem. As far as I can tell there were some problems with the media you could use. This article might help:http://www.sweetwater.com/forums/showthread.php?10128-Tascam-CD-RW5000 You could also try contacting Sweetwater Sound and ask:http://www.sweetwater.com/sweetcare/ They have a great staff.
10/19/2010 2:31:14 PM •
Tascam Music
Answered
on Oct 19, 2010
Question- Can I record songs or musics
Here are some good links for you:http://audacity.sourceforge.net/ ( Audacity is a free recording program ) also:http://www.reaper.fm/ ( Reaper is the software I use and is full featured and worth the licence fee and free to try) also:http://www.recordingreview.com/ ( excellent site to answer all your recording questions. Note the free download.)
8/30/2010 10:19:39 PM •
Tascam Music
Answered
on Aug 30, 2010
TASCAM CD-D4OOO
If you are trying to copy disks that are copyrighted, the unit is likely locked out with copy protect firmware from doing copies.
3/17/2010 4:44:20 AM •
Tascam Music
Answered
on Mar 17, 2010
How to with tascam dp-02 dp-02cf
You can use headphones or monitor speakers that are hooked to an amp. If you don't have one ,consider downloading a manual:http://www.tascam.com/i-3582-232-128-1-4A000F90.pdf Pay attention to the caution on page 9 and the hookup diagrams are on pages 12 and 13. Hope this helps.
1/25/2010 10:38:07 PM •
Tascam Music
Answered
on Jan 25, 2010
