20 Most Recent
Sony Ericsson W960i Cellular Phone Questions & Answers
Ad-hoc PAN bluetooth
I forgot security number of my nokia 701.what i can do for get it or format mobile. please help me.IMEI 358272047510014
My W960i cannot switch on?
Hello:1.Check the device's battery level for at least two bars of strength. 2.If the battery level is low, charge the battery. 3.If the issue is not resolved, remove the back cover. 4.Remove the battery. 5.Wait 10 seconds. 6.Press and hold the W key. 7.While pressing down the W key, re-insert the battery. •The device restarts and after approximately 15 seconds, the 'Recovery' screen appears•Release the power button but *continue holding the home button*, for another 30 seconds.StepThanks
How to unlock country code
Hello My Dear Friend Your Solution::::defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
Keypad on W960i not working:- The number 7 key broken
I fitted a new keypad on my 960i some time ago (funnily enough for the same reason - no.7 not working!) and I'm pretty sure you will find that when your new membrane arrives, it is a complete unit with buttons and contacts all enclosed together, connected to the phones' circuit by a ribbon with a tiny plug on the end.. hope this helps....
Cannot access the web.
Take it to your local phone shop because it sounds like your not getting internet connection at all.
W960I FM IC FULT
There is nor repair to this device, as the board is assembled by PPS [Pick Place and Solder] machines. It is very difficult to repalce any of these ICs, by normal hand soldering machines. Moreover, these ICs will be very difficult to get from open electronic spare part market.
http://www.dataentryjobs.us/67948.html
