20 Most Recent
Franklin Industries Franklin Chef Ice Cube Machine FIM400 Questions & Answers
Water doesn;t stop
I don't know a lot about this machine but it could be that the water inlet value is not working correctly
4/8/2014 4:03:12 AM •
Franklin...
Answered
on Apr 08, 2014
Franklin FIM35 continues water alarm even days
I searched and searched for a fix and here was mine. The sensor wire was shorting out on the drip pan (which was not wet to the touch) above the compressor causing the alarm. I removed the clip and re-rigged it so the bare wire is not touching the sidewall but is positioned so that it could still sensor and alarm in an actual overfill.
10/31/2013 9:11:48 PM •
Franklin...
Answered
on Oct 31, 2013
The Ice Machine is pulling
sounds like you need to change compacitor on compressor or your compressor needs replaced i would change compacitor first and if not helping then change compressor even if you buy compacitor and it doesnt help you still need to have a new one for the new compressor
3/30/2013 7:28:58 PM •
Franklin...
Answered
on Mar 30, 2013
The water is not flowing
Dig into the res and find the pump is what I would do. I would try and oil the motor and then I would run some ice machine cleaner through it. You may need to get the motor out and take it to a supplier to be identified. You might come out better doing this because their are cheaper generic pumps around. Here in the usa we use Grainger and Johnstone for pumps and such. Most of the time though the pump motor simply needs oiling and a good cleaning. These pump s start around $200 bucks and go up. If you need further help, reach me via phone at
https://www.6ya.com/expert/dan_73bbd84fe1d95b61
6/11/2011 4:37:51 PM •
Franklin...
Answered
on Jun 11, 2011
