Geha Primo 800 Shredder
Take a brief Survey Take a brief Survey   Add to My Products Add
Problems with Geha Primo 800 Shredder?
Troubleshooting and Support
Solved Problems for Geha Primo 800 Shredder RSS Feed Post a New Problem
HR Specialist
shredder jammed - took apart to get top off, but still unable to get the jammed paper out of roller
1 Solution
Ativa DQ120D
Motor has not been running. When I put a piece of paper in, the overheat/overload lights come on. I believe everything...
1 Solution
Fellows ps60c-2
I have a fellows ps60c-2 shredder and after I removed the seven screws I could not get the powerhead apart. I need to...
1 Solution
Rexel rdx1750 shredder jam
The shredder got jammed with wet paper and the feed slot was full of compacted dry paper when I inherited it. I cleaned...
1 Solution
Shredder won't shred any more.
Shredded 5 or 6 credit cards, one at a time. Will not shred anything now. Can go in reverse, but not forward. Unplugged...
1 Solution
Fellowes Shredder Parent Part # 38605
I have a Fellowes Shredder that needs a new plastic gear. Fellowes tells me that they cannot locate the part due to the...
1 Solution
Shredder will not sut down when finished
My shredder runs continually after a piece if papper is shredded. How can I correct that?
1 Solution
Unsolved Support Problems
Unsolved Problems for Geha Primo 800 Shredder RSS Feed Post a New Problem
bands instead of fragments
perhaps, after the improper repair blades do not cut across a sheet .. cuts on the band width 0.15in, but not cutting...
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Max Sheet Capacity12 · 4
Speed15.75 ft./min.
Cut StyleCross-Cut · Strip-Cut
Throat Size8.86 in.
Shred Size0.15 in. · 0.14 x 0.98 in.
Other Features
Shredding OperationAutomatic
Integrated WasteWith Integrated Waste
Overload ProtectionWithout Overload Protection
Full Bag IndicatorWithout Full Bag Indicator
Accepts StaplesAccepts Staples
Dimensions
Depth7.87 in.
Height15 in.
Width12 in.
Supported Models
Cross-Cut, Strip-Cut
Sponsored Links
Loading problems.
Top Shredder Experts
fellowes
5 solutions
Shredders
Ask Me
Guru
CopierOn
1 solutions
Copiers, Shredders
Ask Me
Wiz
jusus
2 solutions
Computer Hardware, Computer Input Devices...
Ask Me
Wiz
Repair Service
Find Shredder Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
