FixYa.com
Geha Primo 1500 Shredder
All Products > Geha Primo > Shredders
Problems with Geha Primo 1500 Shredder?
Search inside Geha Primo 1500 Shredder Knowledgebase
Troubleshooting and Support
Solved Problems for Geha Primo 1500 Shredder RSS Feed Post a New Problem
got jammed when a thick paper bundle was...
got jammed when a thick paper bundle was inserted It seems the motor is running,but gears,(teeth) are not moving
1 Solution
Does anybody know the web site for Telko...
Does anybody know the web site for Telko paper shredders?
1 Solution
Fellows ps60c-2
After I removed the seven screws there is something holding this together yet. I need to know what is holding this...
1 Solution
Fellowes Shredder Parent Part # 38605
I have a Fellowes Shredder that needs a new plastic gear. Fellowes tells me that they cannot locate the part due to the...
1 Solution
Shredder will not sut down when finished
My shredder runs continually after a piece if papper is shredded. How can I correct that?
1 Solution
No light, no nothing
The light doesn't come on it doesn't make a sound or anything. I have pulled the trash can out and put it back in a...
1 Solution
Can't find part number
I have a Fellowes powershred 380cc. The white nylon gear located on the motor drive shaft is missing a tooth. I can not...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Geha Primo 1500 Shredder RSS Feed Post a New Problem
WE HAVE A STAPLES SHREDDER
WE HAVE A STAPLES SHREDDER MODEL SLP-1506X AND IT JUST STOP WORKING PLEASE HELP WE CAN NOT FIND THE BOOK
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Max Sheet Capacity12 · 22
Speed18 ft./min. · 16 ft./min.
Cut StyleCross-Cut · Strip-Cut
Throat Size9.45 in.
Shred Size0.13 in. · 0.15 x 1.18 in.
Other Features
Shredding OperationAutomatic
Integrated WasteWith Integrated Waste
Overload ProtectionWith Overload Protection
Full Bag IndicatorWith Full Bag Indicator
Accepts StaplesAccepts Staples
Dimensions
Depth9.33 in.
Height21 in.
Width14.8 in.
Supported Models
Cross-Cut, Strip-Cut
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
