Geha Primo 3900 HS Shredder
Take a brief Survey Take a brief Survey   Add to My Products Add
Problems with Geha Primo 3900 HS Shredder?
Troubleshooting and Support
Solved Problems for Geha Primo 3900 HS Shredder RSS Feed Post a New Problem
Primo 3900
I spoke with you yesterday about issues I was having with this equipment. You were going to get back with me and never...
1 Solution
Royal ORCA 3500 paper shredder
Before I begin describing my dilema, is there a fee for using this chat site for repair advice?
1 Solution
Royal HT 700X Shredder
Had a major jam, had to dismantle the shredder and can't fit the white plastic pice at the end of the cutting blades.
1 Solution
Fellowes P700-2 Shredder Reverse only need...
it will run in reverse only, any ideas?
1 Solution
Office max paper shredder
My wife jammed too much paper in our office max shredder (I told her not to) and striped the teeth off the main drive...
1 Solution
Fellowes Shredder Parent Part # 38605
I have a Fellowes Shredder that needs a new plastic gear. Fellowes tells me that they cannot locate the part due to the...
1 Solution
Need Nylon Gear for PX110MX Crosscut...
Gear is a white Nylon Gear with a Small Metal Gear attached to it. I have several Teeth of the Nylon Gear that are gone....
1 Solution
Unsolved Support Problems
Unsolved Problems for Geha Primo 3900 HS Shredder RSS Feed Post a New Problem
have a level 6, won't shred
will run in reverse, but with switch in run mode, the paper jam sensor light comes on and mach. wont work. took cover...
Post a Solution
Shredder won't shred - all paper is...
GEHA Primo 3900 HS Level 6. The maximim number of pages this shredder will do at one time is one; it will run for...
Post a Solution
Primo 3900 HS
Where is the best place to get a PCB for this unit?
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Max Sheet Capacity11
Speed31 ft./min.
Cut StyleCross-Cut
Throat Size15.7 in.
Shred Size0.03 x 0.43 in.
Other Features
Shredding OperationAutomatic
Integrated WasteWith Integrated Waste
Overload ProtectionWith Overload Protection
Full Bag IndicatorWith Full Bag Indicator
Accepts StaplesAccepts Staples
Dimensions
Depth18.5 in.
Height35.7 in.
Width23.4 in.
Sponsored Links
Loading problems.
Top Shredder Experts
CopierOn
1 solutions
Copiers, Shredders
Ask Me
Wiz
fellowes
5 solutions
Shredders
Ask Me
Guru
jusus
2 solutions
Computer Hardware, Computer Input Devices...
Ask Me
Wiz
Repair Service
Find Shredder Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
