Geha Primo 4001 HS Shredder
Take a brief Survey Take a brief Survey   Add to My Products Add
Problems with Geha Primo 4001 HS Shredder?
Troubleshooting and Support
Solved Problems for Geha Primo 4001 HS Shredder RSS Feed Post a New Problem
Fellowes Shredder Parent Part # 38605
I have a Fellowes Shredder that needs a new plastic gear. Fellowes tells me that they cannot locate the part due to the...
1 Solution
Shredder will not sut down when finished
My shredder runs continually after a piece if papper is shredded. How can I correct that?
1 Solution
Forward Shreading judders
When not used for a few minutes paper is judders forward very slowly for about 10 seconds & then processds as...
1 Solution
My Durabrand Shredder, model WM6X,.
The motor runs, but the blades do not engage. Both Auto and Reverse
1 Solution
No light, no nothing
The light doesn't come on it doesn't make a sound or anything. I have pulled the trash can out and put it back in a...
2 Solutions
Broken plastic gear tooth - Fellowes P55-C...
I have a P55c Fellowes Shredder, the engine runs but it wont shred because the teeth have sheared from one of the...
2 Solutions
Fellows ps60c-2
After I removed the seven screws there is something holding this together yet. I need to know what is holding this...
1 Solution
Unsolved Support Problems
Unsolved Problems for Geha Primo 4001 HS Shredder RSS Feed Post a New Problem
Geha Primo 4001 HS Shredder Problem
Unit was exposed to 208v due to an open neutral problem at the panel. It smells like the control circuit board fried....
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Max Sheet Capacity19
Speed30 ft./min.
Cut StyleCross-Cut
Throat Size15.7 in.
Shred Size0.03 x 0.43 in.
Other Features
Shredding OperationAutomatic
Integrated WasteWith Integrated Waste
Overload ProtectionWith Overload Protection
Full Bag IndicatorWith Full Bag Indicator
Accepts StaplesAccepts Staples
Dimensions
Depth18.5 in.
Height37.8 in.
Width23.4 in.
Sponsored Links
Loading problems.
Top Shredder Experts
CopierOn
1 solutions
Copiers, Shredders
Ask Me
Wiz
fellowes
5 solutions
Shredders
Ask Me
Guru
jusus
2 solutions
Computer Hardware, Computer Input Devices...
Ask Me
Wiz
Repair Service
Find Shredder Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
