20 Most Recent Toshiba Satellite Pro M300-S1002X Notebook Questions & Answers
2answers
Toshiba M300 screen turns white blank.
White screen means that your lamp (back light) is working absolutely fine, but you could have a loose connection for the data ribbon cable, which sends the images to the monitor.
Carefully open laptop to reach its lcd, there must be ribbon cable which looks like this: mrc-0069.gif
It is very sensitive so be very careful with that, very gently remove this from the chip and reconnect it.
Hope this helps, Please feel free to ask me any further.
4/16/2014 9:31:46 AM • Toshiba... • Answered on Apr 16, 2014
Highst how ram suport
8GB
3/11/2014 11:00:11 AM • Toshiba... • Answered on Mar 11, 2014
Gateway laptop pad dont work any more with out a mouse connected
Okay, the drivers might have failed. Try going to device manager by clicking on start at bottom left (assuming you're not in win8) Then right click on "My Computer" then click on "properties" then click on "Device Manager". under "Mice and other pointing devices" is there an icon with a yellow triangle and an exclamtion mark? if so right click and choose "update driver software"
11/28/2013 10:38:14 PM • Toshiba... • Answered on Nov 28, 2013
My acer aspire 5516 says my ati catalyst install manager has stopped working. How do I fix it?
Is it disabled? Take a look at this procedure: http://www.elmajdal.net/win7/Disable_Enable_Windows_7_Startup_Programs.aspx OR re install the driver from Acer Support: http://www.acer.com/worldwide/support/ OR go to AMD and select your Graphics Adapter and download CCC at : http://support.amd.com/US/Pages/AMDSupportHub.aspx
2/28/2013 10:51:32 PM • Toshiba... • Answered on Feb 28, 2013
My toshiba notebook m300 does not have HDMI port
It does not have a HDMI port
12/25/2012 11:03:39 AM • Toshiba... • Answered on Dec 25, 2012
LAPTOP KEEP HANGING EVEN IN SAFE MODE
Press windows button and in the search type msconfig go to startup tab and uncheck those you dont want to start.
scroll to the bottom toolbar bottom of screen right click you can select task manager applications also processes you will see whats running on your computer and ticking over you might have a virus
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system must be registered
Win7/Vista/XP 64 bit
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
if you see something running that you does not need to be running select end now then you might you might uninstall that particular program
and some unnecessary programs
you should also check leads from motherboard to hard drive for secure dust free connections
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now
click start tick in both boxes this will schedule to on restart
do not have any input while chkdsk utility is in progress any might damage your computer
also you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
then defragment your hard drive
adding more ram is the best way of speeding up a computer
If youre not sure if a module is right for your system use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules
you should always ask for a guarantee on compatibility before purchasing any ram and buy working pairs if possible
you might have to many programs running at the same time putting to much strain on the CPU central processing unit
try uninstalling a few unnecessary programs
This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have.
Delete the files using Disk Cleanup
If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup.
It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need.
Open Disk Cleanup by clicking start all programs accessories system tools and then clicking Disk Cleanup.
In the Disk Cleanup Options dialog box, choose whether you want to clean up your own files only or all of the files on the computer.
If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
If the Disk Cleanup Drive Selection dialog box appears, select the hard disk drive that you want to clean up, and then click OK.
Click the Disk Cleanup tab, and then select the check boxes for the files you want to delete.
When you finish selecting the files you want to delete, click OK, and then click Delete files to confirm the operation.
Disk Cleanup proceeds to remove all unnecessary files from your computer.
Watch the demo (1:00)
this should speed up your computer
hope this helps
11/5/2012 12:39:48 AM • Toshiba... • Answered on Nov 05, 2012
2answers
Is there any HDMI port
Full listing of specs at this site [link] state you only get VGA out with this model.
3/19/2011 7:23:27 AM • Toshiba... • Answered on Mar 19, 2011
Web cam does'nt function since
Download the correct drivers from toshiba.com
That will help but if they do not list Win7 drivers, there are none.
1/19/2011 11:20:09 AM • Toshiba... • Answered on Jan 19, 2011
When I try to open
Uninstall current driver. Clean registry with CCleaner, Restart you PC. and install it again from below:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=1998679&rpn=PSMD1U&modelFilter=M300-S1002X&selCategory=2756709&selFamily=1073768667#
hope it will work now. Thanks for joining us.
Have a nice day.
1/9/2011 11:41:52 AM • Toshiba... • Answered on Jan 09, 2011
I cannot connect my external
Install the external hard drive into an USB hard drive adapter case. You can then connect this into the Toshiba's USB port. The Toshiba will see this as an external storage device.
1/8/2011 9:27:34 AM • Toshiba... • Answered on Jan 08, 2011
When I try to open
i have no controls for the built in webcam on my toshiba satellite pro m300
1/8/2011 12:16:37 AM • Toshiba... • Answered on Jan 08, 2011
2answers
I can not install driver
You can download any/allthe Windows XP or Vista device drivers for your model laptop from the ToshibaWEB site from their download page. Make sure you enter the model of your laptopso you can get the correct drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsphttp://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
11/18/2010 9:11:19 AM • Toshiba... • Answered on Nov 18, 2010
Toshiba Satellite M300 won't detect power when
If there is no problem with the battery(does it hold a full charge?) or power cabling (unnatural bunching inside the plastic sheath, frayed wires etc), then the power adapter is not providing enough current to run and charge your laptop battery at the same time. This would suggest a hardware issue with your power adapter, consider replacing it.
10/11/2010 1:47:33 AM • Toshiba... • Answered on Oct 11, 2010
Hi I bought a Toshiba Satellite M300 PSMD4L-01W004
the connector is the most obvious place to start,During the 90's this really was the achillies heel for most laptop manufacturer,this was probably in the top 5 complaint at repair shacks.
technology has made things somewhat better but some models still have faults in this area,that and the fact when dropped this the hinge area come under considerable stress/fractures
9/16/2010 10:57:49 PM • Toshiba... • Answered on Sep 16, 2010
What does !!0xc0190036 !! 808/92134 (netlogon.dll)
That DLL file is part of Windows security. You have entered a bad password in too many times and the OS has locked the PC down.
6/24/2010 11:28:49 PM • Toshiba... • Answered on Jun 24, 2010
2answers
My laptop won't charge
What do u mean by "adjust the cord" ? If u have to adjust by twisting the jack in the power input port then it is neither the fault of the cord nor the of the battery but may be the fault of the power input port.
Go to Toshiba service center and they will solv the prob.
6/18/2010 2:13:16 PM • Toshiba... • Answered on Jun 18, 2010
How do i reformat using recovery disks
after formatting u can use recovery data because what u have lost your fail u can recovery it
6/14/2010 5:19:40 AM • Toshiba... • Answered on Jun 14, 2010
Toshiba M300, does not want to start up
Hi, "shut down the computer; restart the computer, next "when the "message: unable to start computer, select from the different "options, 1. Restart to ("Repair"), once the computer complete the "repair" if it do not start, (choose to repair using "System Restore"), be careful, and very patient because the processes can take a "long time!" Next, if still the problem cannot start the "Windows Programs," then try to start in "Normal Mode." Next try starting the computer in "Safe Mode, all the time for each application following the instruction to the "exact word." (Scan the DiskDrive) if given the "Option?," this will also try to find a way to fix the problem. "Now this is very "Important," if you do not have very important "Files, Personal Data, or just important "stuff" that you have in the computer, meaning "NOTHING TO LOSE," then find the "Option to Restore the Computer to Factory Settings; "Out of Box!, as when you first brought the Computer." Once again make sure you have a lot of time to do this, because its going to take a long time, but I tell you its worth it. I hope for the best! "If you feel this solution was of help, rating it is appreciated, thanks."
5/8/2010 10:46:35 PM • Toshiba... • Answered on May 08, 2010
Toshiba Satellite Pro M300-S1002X Notebook Logo
78 questions posted
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
laptop keep hanging even in safe mode
  • Computers & Internet
