20 Most Recent
ASUS G1SN-A1 Gaming Notebook PC Questions & Answers
I have an Asus G1Sn
Asus will tell you to back up all saved files to an off machine flashdrive or external hard drive, then turn the unit off then turn it on go to computer and open to the search box enter manufacturers default reboot.vIt will reboot your OS from a protected boot sector on your hard drive. If this doesn't fix take it a trusted computer repair service.
Help ID this surface mount componant
That's a burnt resistor. I would guess that is not the only part that is bad. You have a short on the board. There is no way to read the value anymore. I'm afraid you are looking at a new motherboard. For more information, please visit my website at audioserviceclinic.com. Thank you.
Installing ubuntu on
Install within Windows for dual boot. Piece of cake. There should be no reason to change BIOS.
Win 7 BIOS Missing Required License
Window will slowly start disabling itself by having lesser and lesser functions, if it is not activated. Use the Window Product key sticker on you system to register. You may have to call in to get activation key. It differs from product key.
Where can I get a start up disk for my asus
The hard disk may need reseating or it may be faulty.
First - re-seat the harddisk and reboot the computer. If this does not work then reboot and go to theBIOS configuration to see if the BIOS detects the hard drive. If it doesn'tdetect the hard drive then it could be faulty.
Next - to determine if thehard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty.
The hard drive needs to bereplaces in the laptop and Windows installed and the laptop's device driversand your programs etc to get a functioning laptop again.
Asus crash & burn logo
try to turn it off the ASUS laptop and remove the battery. Then put it back and try to turn it on, if it did not turn on, call ASUS immediately for the repair of your laptop...
Asus grafic card problem
Update motherboard bios firmware, update the video card drivers. Try using a different resolution.
Blue vertical line on my desktop
The blue lines are a sign that the screen itself is failing. You can try to reseat the data cables from the motherboard to the back of the screen, but in most cases this is indicative of an immenent screen failure.
ASUS G73jh Start-up Power BUTTON Problem
Hello ,I can take remote access of your system and fix issue for you, one time charges USD 30; pay only if issue is resolved.
Call me at
OneEighthundred,ThreeThreeNine,NineSixThreeFour (Free number).
My Name is Harry.
