20 Most Recent
X2 Systemax NO OS AMD Desktop Computer - AMD Athlon 64 3600+ / 1GB DDR2 / 160GB HDD / DVD-ROM/CD-RW Questions & Answers
Forgotten my computer access code
If you are referring to the power up access code screen that comes up when you first turn on your computer, it can be erased by removing the disc type button battery located on your motherboard. Make sure computer is un pluged from the power source. Remove the button battery for 30 seconds. Re-install it and power the computer up. It will boot up normally. If you are referring to a lock out of your Operating System, you will need to purchase a password recovery / reset program and load it into your computer during start up using the boot drive options selections located in your start up / set up menus. Its usually called: Boot Options or Boot Drive Options
I'forgott my computer access code. What to do?
Do you mean you have forgoten your account login password?. If you have press Ctrl > Alt + Delete and enter you administrator passowrd. This should be administrator for username and password.
Once in click Start > Control Panel > User Accounts. Find your Username and change the password. Click Apply
Log Out and you should be able to log in with your new Passowrd.
If not change the password using your Operation System CD.
What is Computer Access Code
u mean when you first turn it on it asks for a PW,
unplug it (necessary)
then
take off left side cover (when looking at front) (if you have to take out more than 2 screws your doing it wrong)
and pop out the small silver watch battery with a flat screwdriver(push tab) for a few minutes
put everything back
if you dont see it or don't know what your doing leave it alone or you'll screw something up
To create a new access code
Go to the host PC whose access code you would like to change.
Make sure that the GoToMyPC service is running (look for icon in the system tray).
Right-click on the icon in the system tray and select Change Access Code.
Click the Forgot it? link.
Enter your email address and account Password.
On the New Access Code dialog box, enter your new access code, confirm the new access code and click OK.
Note: You will need to be at the host PC to perform this function because you will not be able to log in to your host PC without knowing the Access Code for that PC.
Thats if you want to change the access code but if you are simply looking for your access code you need to get in touch with your group.
Code Access Security is a new concept brought in by the .NET framework. Code access security essentially involves granting permissions to an assembly. Code access security uses the location of assembly and other information about the identity of code as a primary factor in determining permissions to be granted to the assembly. This information about the identity of an assembly is called evidence.
Once loaded in runtime, the code starts executing in the restricted environment depending upon permissions granted to it. If the code is not trusted enough to run or runs but performs an action for which it has no permissions, then a security exception is thrown.
The code access security system means we can stop running of malicious code and also restrict the code to run in a restricted environment where we are sure that it won’t do any damage to the resources. Let us now see few cases where code access security becomes
crucial.
Suppose an organisation is working with some extremely important data, we would use a code access security system to state which code is allowed to access the database and which is not. Similarly if we run an application from a network drive and it tries to access the file on a local drive an exception must be thrown. This can be done using a code access security system.
It is important to know that code access security protects resources like local disk, network, user interface from malicious code. It is not a tool for protecting software from users.
Code access security works on the basis of Code Groups and Permissions.
