20 Most Recent
Lexmark X7350 InkJet Printer Questions & Answers
Need a complete picture of Lexmark X7350
First of all, thank you very much for choosing FIXYA today for your technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.lexmark.com/publications/pdfs/2007/7300/ug_en.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at
WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.See page 18 and 19 of the USER'S MANUAL in the LEARNING ABOUT THE PRINTER section for detailed instructions and illustrations on what the various parts and slots on your printer are.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Hardware problem - papersensor x7350
create
There
could be something blocking the paper path or maybe the printer just needs to
be reset. Remove the sheets of paper from the feeder. Open the printer cover
and remove the cartridges from the carrier. While the cover is open, check
for any foreign objects blocking the cartridge carrier's path and the paper
path. If cartridge area is clear, close the printer cover. Unplug and re-plug
the printer into the power source to reset it. When the printer turns on,
re-insert your cartridges. Load some paper (avoid overloading). Try to print
again. If paper jam continues, then perhaps it's a mechanical problem. Please
don't hesitate to contact Lexmark Technical Support Center for additional
assistance.
Where does it plug in to pc
Your printer must have a USB cable like this one (some printer come without one so you need to buy it):
The square connection on the USB cable goes into this port on the printer:
And the other bit goest into the USB port on the computer:
Any combination of 31 (Photo)
Hello.
The black (#32) cartridge or photo (#31) are always installed in the Left carriage and the color (#33) always in the Right carriage.
The black and photo cartridges are not installed together.
Hope this helps.
I dont know how to scan of my Lexmark x7350
Assuming the Lexxy software drivers are properly installed you simply load up whatever software you want to scan into (paint shop, word etc...) and import from the scanner. Depending on the software you will use either the "import from..." or "acquire" menus items (look through the menus of the particular software you are using). You will get a submenu asking for the source. From this you select "scanner" or "twain". This will invoke your scanner software and from there you follow the prompts.
How do i set the time on a lexmark x464
Usually you need to access the embedded web server on the printer by typing the IP address of the printer into your web browser address bar. This will open a window that will have all the settings available.
