20 Most Recent OKI C5650n LED Laser Printer Questions & Answers
Clean the laser scanners
OKI C5650n LED... | Answered on Sep 30, 2018
I cannot understand why you are using sublimation paper on an LED printer which uses toner. I always thought that sublimation printing is used with dye and not toner. Why it worked in the first place is odd. Anyway I reckon you have worn out the fuser and or the fuser is not reaching temperature which is why its not fusing correctly.
OKI C5650n LED... | Answered on Jul 16, 2017
The toner cartridge might not properly installed. Just try reinstalling or re-insert problematic toner cartridge, after doing it the error should gone.
OKI C5650n LED... | Answered on May 09, 2017
Oki is forcing you to buy a new fuser. If fuser roller, film and thremistors are still in perfect shape, reset is possible with new OEM FB fuse
OKI C5650n LED... | Answered on Oct 22, 2016
tengo una impresora oki y me muestra error fatal en la pantalla que debo hacer para quitarle ese error de mi impresora
OKI C5650n LED... | Answered on Jul 13, 2016
I expect you have an extra tray fitted. This error refers to this option. Turn the power off and lift the printer off the second tray .Now turn it back on and it should print ok. If so then throw away the optional 2nd tray as it has gone faulty.
OKI C5650n LED... | Answered on Jun 18, 2016
check the fuser unit for paper/media stuck to the orange fuser roller. power off machine and re-install. If that dont work fuser unit must be replaced
OKI C5650n LED... | Answered on Dec 17, 2014
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
OKI C5650n LED... | Answered on Jul 22, 2014
TRY THIS
8. Restart printer.
OKI C5650n LED Laser Printer Logo
Popular Tags
74 questions posted
Popular Products
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
WTF Chuck.....
WTF Chuck.....
Clive
Clive
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
C OKI
  • C OKI
Most Popular Question
reset fatal
  • Office Equipment & Supplies
