20 Most Recent Plustek OpticFilm 7300 Film Scanner Questions & Answers
First of all you need to check whether the lock behind your scanner is open or not. If not, unlock it.
Two, if the secure lock has been opened already, but the system is still incapable of identifying your USB device, you can check if you have installed a scanner driver or if the driver is correct for your device.
Step 1 Find out your scanner model.
Step 2 Check Scanner driver in the Device Manager sheet.
Step 3 If you have not installed a driver yet, or the driver is incorrect, search on the website and download the supporting and latest driver for your USB scanner. Before installing the driver, uninstall the incorrect one. Note that when you install the driver, make sure it works well with your system.
Three, you can try to swap your scanner onto another USB port. Because if the cable order in this port is not right, it would also generate the failure above, which often happens in the motherboard's front USB port.
Four, your motherboard might not be compatible with your scanner's port, so you are unable to find out this device in your computer. To cancel it, you need to check the model of your motherboard chipset, download its latest driver or the corresponding motherboard USB patch from the website and then install this driver or patch.
Plustek... | Answered on Feb 06, 2011
You can download manual from the website
Plustek... | Answered on Sep 12, 2009
In the Twain driver for your intellscan, there should be a selection for the type of scan. It should be set to "black & White Negative" or "Color Negative". The program you use to edit the scanned file should be able to change it to a positive if the scanned result is still negative. Programs such as Photoshop, Paint shop Pro etc can use Twain to have the scanner scan directly into them. There the phot (negative) can be edited and saved.
Plustek... | Answered on May 30, 2009
Has the scanned slides each been given a File name and saved on the Hard Drive? If yes , burn the files onto a disk from the hard driver using the file names to burn.
Plustek... | Answered on Feb 16, 2009
This scanner does not work properly with Windows 7 and there is no fix yet that I know. Also, if you have another scanner installed, such as an all-in-one printer, it will cause conflicts. Having both Windows 7 and another scanner installed would cause this problem. Sorry it's not a fix, but without knowing your operating system (it takes a beefy computer to run) and your setup I can't be more specific.
Plustek... | Answered on Mar 29, 2015
My scaner is 7500se .and I want the driver too...could you help me
how to use it on ubuntu .
my Email is 1999@i1999.cn
thanks
Plustek... | Answered on Oct 14, 2012
looks like someone has got it working
good luck
Plustek OpticFilm 7200 Driver update
Plustek Office... | Answered on Nov 16, 2016
First, make sure you are downloading from the proper site: http://plustek.com/usa/support/drivers-and-downloads.html .
If you cannot download from your computer, try a different one and put the drivers on a thumb drive to use on your computer.
Plustek Office... | Answered on Jun 08, 2015
This is there home site with drivers and software: http://plustek.com/usa/support/drivers-and-downloads.html
I would start there. Good luck!
Plustek Office... | Answered on Jan 02, 2015
Plustek OpticFilm 7300 Film Scanner  Logo
14 questions posted
Top Plustek Office Equipment & Supplies Experts
Thomas F. Schneider
Chris Medina
Are you a Plustek Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Opticfilm Plustek
  • Opticfilm Plustek
Most Popular Question
just trying connect scanner pc
  • Office Equipment & Supplies
