20 Most Recent Hannspree XM-S Boston Monitor Questions & Answers
There should be no reason why you can't set the correct display setting for the monitor via the HDMI cable.
Click on the Start Menu and type in the search box display and hit enter. A new window will pop up. From the left hand side click on Change display settings. Now, click on the Resolution tab and use the slide bar to select 1024 X 768 and click on apply.
Hopefully this will work and fit the picture on the screen. If this does not work please post back with information about what kind of computer you are using for example desktop/laptop.
Good luck.
Hannspree XM-S... | Answered on Aug 05, 2010
The light is blinking can indicate two things, one- it see short circuit such as short circuit in the backlight inverter board, this board consume most of the power and runs hot, so it trying to shut itself off, two- the power supply is bad, look for bad filter capacitors, which is more likely, for bulging top, learn more here:
http://en.wikipedia.org/wiki/Capacitor_plague
Hannspree XM-S... | Answered on Nov 01, 2009
Not sure why you would need an internet connection to recover data. Maybe it has ransomware on it? There are CD's you can burn that can run a Linux environment and check fr malware. The Hirens CD comes to mind.. Try downloading it, burn to CD or create a USB install and run some malware programs on it. Or use a Windows 10 install to reinstall a new system.
Hannspree... | Answered on Jun 12, 2018
When you say the picture keeps dropping, is it going to the black or blue screen where it says it cannot detect an input/source?
If so that could be a faulty cable, if you have a spare cable to connect to whatever the input you're using is it would be worth trying that.
Hannspree... | Answered on Aug 16, 2016
Hello and good morning,
To clear the cache of any Android powered device, there are a few ways. The easiest way is to download an app from the Play Store that has been written to clear the system-wide cache. One button press and you're done. Just be wary: some apps and games will reset of lose data if you clear they're caches, so be mindful when using a solution like this.
The other way is to tap SETTINGS, then STORAGE, and clear the cache from individual apps.
Hope this answers your question! For faster, personalized assistance, login to 6ya dotcom today!
Hannspree... | Answered on May 05, 2016
If you want, and I can't think why unless you have Vista, to upgrade.
Hannspree... | Answered on Jan 18, 2016
Hannspree XM-S Boston Monitor Logo
14 questions posted
Top Hannspree Computers & Internet Experts
 Mike M
Mike M
Steve Allison
Steve Allison
DBurstiner
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Hannspree Computers & Internet
Most Popular Question
moniter quit working light blinking
  • Computers & Internet
