20 Most Recent
Quartet gbc 32S Shredder Questions & Answers
How to open shredder when screews are removed
Looking at the label on the bottom, peel off the left side of the label about one inch and you will find a hidden Philips screw just like the other 6 on the bottom and the parts separate easily.
Shredder is squeaking
You would need to lubricate the unit by running through oiled paper or by spraying oil directly into the feed opening and then running unit in reverse for at least 2 minutes
Good luck
GBC #SC32 auto stop not functioning
take the shredding portion of the shredder off and check in its teeth (while unplugged of course) to check that there are no errant pieces of paper or plastic in the device. You may even want to try and blow out any possible paper stuck inside with some canned air or something.
