20 Most Recent
Quartet gbc 75X Shredder Questions & Answers
On, Fwd, Rvs button has stopped working on my Shredmaster 75X. How do I fix this?
First check the power point is still working - plug in another appliance, like a table lamp. If OK check the fuse in the shredder cable plug.
The commonest reason for a shredder stopping is a paper jam, or running the shredder for too long. By 'too long', many shredders will cut-out after 5 minutes continuous working, and the sensor may take 15 minutes to cool down! Read the manual.
It maybe that the shredder cutters are jammed. Unplug from mains, and lift off top and place upside down. Use a small screwdriver and/or long nosed pliers to poke at any compressed paper wrapped around the blades - can take a while.
Shredder is squeaking
You would need to lubricate the unit by running through oiled paper or by spraying oil directly into the feed opening and then running unit in reverse for at least 2 minutes
Good luck
GBC #SC32 auto stop not functioning
take the shredding portion of the shredder off and check in its teeth (while unplugged of course) to check that there are no errant pieces of paper or plastic in the device. You may even want to try and blow out any possible paper stuck inside with some canned air or something.
