20 Most Recent Alpine MRP-M1000 Car Audio Amplifier Questions & Answers
Is the amp in protect mode? Maybe a red light on the amp. I would also open the amp and check the RCA connections aren't loose. It's usually a solder joint. Swap the amp out as well. Or check your power wire. Sometimes amps come on when it gets remote power, but actually the power wire has a bad fuse or connection.
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
Alpine MRP-M1000... | Answered on Oct 04, 2017
The amplifier may be going into protect mode (even briefly) because you are driving them too hard. Back off on the volume and see whether the problem goes away.
Alpine MRP-M1000... | Answered on Mar 12, 2017
YOUR AMP IS JUNK THEN.
I’m happy to assist further over the phone at https://www.6ya.com/expert/chris_ec38c09da1ae48dd
Alpine MRP-M1000... | Answered on Nov 20, 2013
you ever find out wher t get replacements , i got the same isuue
Alpine MRP-M1000... | Answered on Apr 26, 2013
ok its all in the way you wire them, just remember when you wire your speakers in series, the ohms build(add to eachother) which would make them total of 8 ohms, and if you wire in parrallel the ohm load cuts in half (2 ohms). So you want to wire them together in parrallel then run your wire to the amp. Just so you know though, if you bridge your amp, it will also cut the ohm load in half, so you would see total of 1 ohm which gives you more power, just make sure your amp is 1 ohm stable and your subs can handle it.
Alpine MRP-M1000... | Answered on Oct 14, 2011
Try getting a capacitor. That worked for my 12w7 with that same amp
Alpine MRP-M1000... | Answered on Jun 27, 2011
your amp remote wire is hooked up to the power antena wire therfore when your tuner is on so is the amp when u switch to cd there is no power to the antena ive done that before
Alpine MRP-M1000... | Answered on May 08, 2011
Your best bet will be to wire 2 subs in parallel to the amp. Each sub should be rated for at least 300 watts rms at 4 ohms. This will give you a total impedance of 2 ohms, and your amp will put out 600 watts rms at that impedance. That way, each sub will receive 300 wats rms. I would not recommend wiring subs in parallel, as you will need two 1 ohm subs at 300 watts rms, which are harder to find and will be more expensive. A parallel circuit is the most efficient way to do it.
Alpine MRP-M1000... | Answered on Mar 07, 2011
this amp is rated at 600w at 4 ohms and 1000w at 2 ohm so as long as you calculate your speakers to match the ohm specs of the amp you can hook up
parallel = pos to pos and neg to neg of the 2 speakres
2 - 8 ohm speakers in parallel = 4 omhs
2 - 4 ohm speakers in parallel = 2 ohms
series = pos to neg of the 2 speakers
2 - 1 ohm speakers in series = 2 ohms
2 - 2 ohm speakers in series = 4 ohms
Alpine MRP-M1000... | Answered on Feb 23, 2011
Where is your subwoofer gain set? Also, what crossover frequency do you have the sub set to?
Alpine MRP-M1000... | Answered on Jan 10, 2011
Alpine MRP-M1000 Car Audio Amplifier Logo
49 questions posted
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Robert Salgado
Robert Salgado
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Alpine Car Audio & Video
Most Popular Question
alpine mrp m1000
  • Car Audio & Video
