20 Most Recent Sharp LC-32D64U LCD TV Questions & Answers
Hello Barbara,
I'm Joe, thank you very much for choosing FixYa for your technical support needs.
I would be pleased to provide whatever assistance you need with hooking up your Direct TV receiver to your TV, or with hooking up your DVD player to your TV.
In order to provide you with the proper specific detailed instructions, could you please COMMENT back here to this page and provide the exact model numbers of your TV, your DVD player, and your Direct TV receiver, since exact connection instructions can vary between different models.
Normally the model numbers are printed on a label on the back panel of each device.
You can use the POST A COMMENT button near the bottom of the screen to post this additional information and I will receive it right away. Then I can proceed to look up and provide you with the appropriate User Manuals for each device and also the necessary instructions to hook them up.
Thank you very much, I look forward to hearing back from you and assisting you further.
Joe.
Sharp LC-32D64U... | Answered on Feb 21, 2015
Update your Driver, if you have an AMD or Nvidia graphics, you can download it from.
http://support.amd.com/en-us/download
or
http://www.nvidia.co.uk/Download/index.aspx?lang=en-uk
Download and install the latest version, "Start" , Right Click on "Computer" and click on "Properties" and "Processor" will tell you which version AMD or Nvidia you have and now click on "Device Manager" and expand "Display Driver" and you will see what series of the Processor you have example, my processor says AMD Sempron(tm) M100 and in "Display Driver" in "Device Manager" it says I have ATI Mobility Radeon HD 4200 Series.
Downlad the Lastest Driver, install it, Restart your Machine after the machine starts up, down the bottom on the right hand side you should see AMD or Nvidia and you can Right click on the Icon and now you can change your "Set Desktop Area to" 1360 by 768 if your machine allows you to get to that display.
Sharp LC-32D64U... | Answered on Oct 17, 2013
This is surely a problem inside the board. This may need attention by a qualified service technician.
Sharp LC-32D64U... | Answered on Jul 21, 2012
I was able to successfully update my Sharp's firmware by using a USB drive that was:1) formatted in (fat, not fat32)2) had only the one update file (.uvp) and3) a small USB drive (4gb - other posts said 2gb or less)
Sharp LC-32D64U... | Answered on Nov 25, 2011
This kind of symptoms is an indication of fault on the inverter board. The parts gone to malfunction is either the high voltage transformers or the driver transistors and IC's. If you are going to DIY, I would advice you to replaced the entire board because it will cost almost the same rather than troubleshoot it.
Click this LINK to view the inverter board.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Sharp LC-32D64U... | Answered on Aug 01, 2011
Do you mean the LC-60E88UN? The LC-69E88UN isn't listed at Sharp's USA web site.
Try a different channel; different programs will have different resolutions provided (particularly the local stations). How are you connecting the TV to the satellite box? If you are not using component or HDMI, then get the appropriate cable for whichever of those is compatible with your satellite box. Then change switch the output of the satellite box and switch the input if needed for the TV.
With DirectTV, there is a setup menu option to change the output resolution to the native resolution of the TV. So check that. Menu > Fav's and Setup (press Select) go to HDTV > Video tab. Set Native option to On. The only issue will be that channel changes will be slow as the receiver checks the native resolution. Dish Network probably has a similar feature but it may be in a different menu area. Check your documentation. Both companies have manuals online when you look up the equipment.
I hope this helps.
Sharp LC-32D64U... | Answered on Jan 23, 2011
It can be in safety shutdown mode due the failed DC filter caps, shorted circuits in the backlights inverter boards, main board problem. You need to do some inspection first.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Sharp LC-32D64U... | Answered on Dec 14, 2010
This tv i have one too a Sharp Aquos 46" inches,happen to me alot of times.Power light and OPC light flashes together.This problems is the tv Tuner board have problems and the causes,but this tv is still useable.Every times Power light and ORC light are flashing just push the power button again wait some times the tv backlight will come up and have picture work right away.Sometimes Power light and ORC light will flashes again.U have to this process sometimes 3 or 4 to it tv to work.Not sure long this process will last,but my opinion if u have to do it like 10 or 12 times.The tv Tuner signal board is on last leg,should be replaced.
Sharp LC-32D64U... | Answered on Dec 08, 2010
According to the manual for the TV, you need to change the resolution on the computer itself first.
The computer resolution should be 1024 X 768 at 60Hz or 1360 X 768 at 60Hz.
After the adjustment made on the laptop, then try the resolution change option.
Sharp LC-32D64U... | Answered on Jun 12, 2009
Menu on remote and make sure you have it on wide screen or 16 to 9
Sharp LC... | Answered on Jan 17, 2019
Hello
If your Roku 3 player is not connecting to WiFi, it is possible that the WiFi signal from the router is out of range. In order to strengthen the signal, move the router and Roku 3 so that there are fewer objects and walls between them.
For any help or support just visit us: www Roku Com Link
Sharp LC... | Answered on May 26, 2018
Sharp LC-32D64U LCD TV Logo
21 questions posted
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
LC Sharp
  • LC Sharp
Most Popular Question
sharp lcd tv lc 32d64u lightning strike
  • Televison & Video
