20 Most Recent
Samsung LN46A750 45.9 in. HD-Ready LCD TV Questions & Answers
I have a problem with
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "
brand name" to your device; in the "
Search box at the top right of the display window of the Homepage" to get gathered related posts.
Samsung turns on and off for itself
hi,
sounds like your power supply is bad. this is a big problem with samsung. Caps on the power supply swell and need replacement. this will cause tv to click on and off. Samsung is getting a classaction lawsuit filed against them for this issue.
Replaced the 4 power capacitors now tv runs for
when the picture goes black, dim the light in the room and shine a bright flashlight on the screen. If you see a faint picture, you have a backlight problem. If this issue came about after you installed the capacitors, double check the installation of your caps. Ensure that you don't have cold solder joints or broken joints!
1ST TIME SETUP OF NEW TV...HAVE AUDIO, NO VIDEO
Are you getting sound through the TV from the DVD, or is the sound from the DVD coming out of your home theater/surround sound system (if you have one)?
If it has more than one HDMI port (on the TV) try changing it. If not look around in your DVD settings as it might think it is only giving audio through the HDMI to a audio/home theatre system. And using the other video outputs to give the video instead.
It shouldn't be a problem with the cable, since it is digital, if it were not to work - nothing would, or the audio would atleast be coming out weird (it it wasn't working).
One side of my tv gets dim and out of focus it is a samsung. At times it works fine
back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
How do I troubleshoot my Samsung TV?
I have sound, but no picture.
Caps can fail with no outward signs. It takes a special meter to test them. Your set may have a back light inverter that powers the back lights. When it fails, the picture cant be seen, but you have sound, to check this look for a picture on the screen using a flashlight
My Samsung Tv modle LN46C600F3F has sound no picture, what could be wrong?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
