20 Most Recent
Panasonic Viera TC-32LZ800 32 in. LCD HDTV Questions & Answers
Need headphone solution for Panasonic c12lcd tv
I have a Panasonic viera 32in lcd hd tv. I'm trying to hook up headphones but there's is no apparent audio output jacks. But there's is only one digtal output jack! is this the jack ? and if it is, what cables do I need to make the headphones work? or am I forced into by an amplifier
Have sound but no picture
likely the power supply failed, the set should have a blink code--if led on front blinking try to count the number and then a pause and repeats it, 7 and or 10 blinks are common.Keep in mind if you find a error code like these it would not say which exact part is bad only a general idea of what is wrong.
When i plug in the lead with 3 colours
S video is a 4 pin lead that supplies vision only. Because the cable is new doesn't mean it works. I would take the cable and camcorder back let the shop try to get it working or issue you a replacement especially if still covered by the guarantee.
To check the cable is a simple process involving the use of a multimeter. You are checking to make sure the leads have a resistance.
