20 Most Recent LG 26LG30 26 in. LCD TV Questions & Answers
hello try changing the picture ratio...what i mean is try 16.9 widescreen or 4.3 ledder box the tv is tryn to produce a pic bigger or smaller than what you have keep tryn different picture ratio's
LG 26LG30 26 in.... | Answered on Aug 14, 2015
Connect VGA (D-sub 15 pin) cable from PC to TV (RGB PC) input jack. Connect audio cable from PC to TV. Set screen resolution on PC to be compatible with TV, such as 800 X 600 or 1024 X 768 etc. Select on the TV, the PC INPUT using the TV remote when ready to use as monitor.
Under PICTURE on the TV select SCREEN (RGB-PC). You can AUTO-CONFIG or you can set resolution manually to the same you set PC to. Other adjustments can be done here as well to get optimum picture on TV from PC.
LG 26LG30 26 in.... | Answered on Jun 28, 2015
There is no external reset button to this TV. You have to enter the Service Mode option to make it a factory reset. you should have its original remote control to do this. No universal remote control can be used for this purpose.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
LG 26LG30 26 in.... | Answered on Jul 27, 2014
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
LG 26LG30 26 in.... | Answered on Mar 15, 2014
Change the backligth inverter board
LG 26LG30 26 in.... | Answered on Nov 22, 2013
most the time they are set to 3 or 4 just depends what channel your cable comes in on
LG 26LG30 26 in.... | Answered on Aug 04, 2013
I think there might be a setting of shutdown and reopen. If you know how to reset the settings then do it. Your problem will solve.
LG 26LG30 26 in.... | Answered on Jul 23, 2013
opreting hang problam
LG 26LG30 26 in.... | Answered on Jun 13, 2013
Check its back-light inverter board and back-light CCFL lamps. In most cases, lamps found faulty. Check and replace the faulty ones. If you wish to get more details, check this site.
LG 26LG30 26 in.... | Answered on Feb 11, 2013
you have a bad cap in the power supply
these are can shaped device thet if bad will vent anf put up on the top the valoue is wrtten on the side trplace them and you should be good to go
LG 26LG30 26 in.... | Answered on Dec 04, 2012
LG 26LG30 26 in. LCD TV Logo
87 questions posted
Steve Allison
Steve Allison
View Most Popular
  • LG Televison & Video
Most Popular Question
bande verticali colorate
  • Televison & Video
