20 Most Recent Toshiba 32CV510U LCD TV Questions & Answers
check some leak or bulged capacitors at the power supply board then replace it.
Toshiba 32CV510U... | Answered on Oct 03, 2012
It sounds that the T'Con board is faulty. This is a common fault to most of the LCD TV, irrespecitve of brand and model. Just visit this site named 'Electro-help'. so many similar faults and repair to them are described in detail there. Check this link and select the site named above.
Toshiba 32CV510U... | Answered on Jul 14, 2012
Possible that the main power supply had failed, attempt to open and check only if you are equipped:
click on for tips:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Toshiba 32CV510U... | Answered on Sep 30, 2011
sounds like you may have also had a power spike and possibly fried the tv. have you tried unplugging the tv for about 30 mins and plugging it back in? some tv's have built in surge protectors that need to be re-set
Toshiba 32CV510U... | Answered on May 14, 2011
When one capacitor goes bad the others aren't far behind, and they might not yet show external signs that they have also failed. This is why it strongly recommended to replace them all.
The screen goes blue when there is no input coming in the image processor. Since the menu is also missing it means that the defect is related to the control processor on the mainboard. Check the other voltages on the power source - especially the 5 volt one - and then verify the mainboard for defective parts - the small capacitors that filter the power going to the processor.
Toshiba 32CV510U... | Answered on Nov 02, 2010
More likely to have power supply failure, the power supply is always running to supply the power to the processor waiting to get th turn on command form the remote control. Look for bad caps in the power supply and check the fuse, Need to verify if you do have the standby 5vdc, you must have this voltage before going any further.
Learn more here:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Parts:
http://www.shopjimmy.com/catalogsearch/result/index/?q=Toshiba+32CV510U+&limit=100
Toshiba 32CV510U... | Answered on Jun 14, 2010
go into audio settings see if speakers on if ok try input or source change some have pic no sound
Toshiba... | Answered on Sep 15, 2019
Try https://www.manualslib.com/products/Toshiba-49l310u-4149107.html
Toshiba... | Answered on Sep 13, 2019
Toshiba 32CV510U LCD TV Logo
Popular Tags
16 questions posted
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
yellow led toshiba 32cv510u flash all
  • Televison & Video
