Philips DVDR3576H  DVD Recorder
Problems with Philips DVDR3576H DVD Recorder?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Troubleshooting and Support
Solved Problems for Philips DVDR3576H  DVD Recorder RSS Feed
Click here to get instant support from our best Experts!
View More Results for Philips DVDR3576H DVD Recorder
Questions and Unsolved Support Problems
Unsolved Problems for Philips DVDR3576H  DVD Recorder RSS Feed
Answer
Is it possible to play region 2 dvd's on a region 1 dvd player. we have the phillips dvdr 3576h
Answer
what type of video files will dvdr3576h recognize throught the USB port.
Answer
I have used a Philips DVDR3576H for less than a year to regularly record programs off the air. ... (More)
Answer
the dvd player quit working;everything else seems to work.
Answer
Once in a while, something I have recorded on the hard drive will freeze when I try to play it back.... (More)
Answer
Philips DVDR model DVDR3576H w/ HDD; the clock does not index, it stays at the time you set it. Have... (More)
Answer
I have a coax from my cable box to the Ant in of my Philips HDD recorder/player. I have RCA cables... (More)
Find a Manual
Philips DVDR3576H DVD Recorder Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
Tips & How To Guides for the Philips DVDR3576H DVD Recorder
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Aveis Electronics
Aveis Electronics is owned by Daytec Corp. which is solely owned by Daewoo. Their warranty number is 1-877-329-8351.Daytec also has a website. written by polarbear195
My player does not read disks
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will... written by ginko
If your dvd/cd/disc player is skipping
If your DVD player, cd player or any console or unit that uses a compact disc begins to skip intermittently, please before wasting money on a disc... written by fieldy14
Factory Reset
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down... written by xmarine2847
Help FixYa, Help you and help others. Share your User maunals and service...
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the... written by stoneheaded
Having trouble recording TV broadcast to DVD?
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then... written by MateusDIY
Owners Manuals
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems... written by stoneheaded
Dish Network DVD Remote Codes
DVD Codes BRAND COMBO CODE Aiwa DVD 634, 694, 751 Alpine DVD 653 ... written by stoneheaded
I need help with
near zipcode:
Please enter your zipcode
Search
Top Repair Providers for Philips DVDR3576H DVD Recorder
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Ratings for the
Find a Warranty
Specifications for Philips DVDR3576H DVD Recorder
Product MPN
MPN
DVDR3576H
Key Features
TV Tuner
With TV Tuner
Playable Disk Types
DVD-RW · CD-R · CD-RW · DVD-R · DVD+R · DVD+RW · DVD Video · SVCD
Playable File Formats
MPEG2 · DivX · MPEG1
DVD Type
DVD Recorder
Number of Discs
Progressive Scan
With Progressive Scan
Video
Video Upconversion
1080p (HDTV)
Video DAC
10 bit / 54 MHz
Audio
Surround Sound
Dolby Digital (Digital out only)
Audio DAC
10 bit / 54 kHz
Connections
Outputs
Composite x 1, S-Video x 1, Component x 1
Inputs
Composite x 1 · S-Video x 1 · Analog Audio x 1
Front Panel
USB 1.1 · Audio Input · Composite Video Output
Recorder
HDD Size
160 GB
Recordable Media
DVD-RW · DVD-R · DVD+R · DVD+RW
Programmable Timer
12 Events within 30 Days
Dimensions
Depth
16.26 in
Height
5.79 in
Width
16.54 in
Weight
7.5 lb
Other Features
Exterior Color
Black
Philips Contact Information
Main support number1-888-PHILIPS
Describe your problem:
Top DVD Player Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
