20 Most Recent
Polycom SoundStation2 with Two Extended Mics (220016200MIC) Questions & Answers
We have a dial tone but there is a fuzzy sound in
I have reviewed your problem and have the fallowing for you to aces.
First, try disconnecting the phone line coming into the phone from the wall outlet.
Press the talk button and listen to the background noise over the receiver. If you hear static, fuzzy or a humming, your power supply or cube is allowing A/C to bleed thru the circuity and the cube should be changed.
But, you have also complained that the phone will not dial out.
If this is the case, the phone should be replaced and the cost to have this phone repaired would not be in your best interest.
I hope this information has been of some help.
Please rate kindly...
11/12/2009 7:00:11 AM •
Polycom...
Answered
on Nov 12, 2009
Polycom voicestation 300
are you sure this feature is not blocked on your line? check with another phone connected to the same socket if you can dial the same numbers
