20 Most Recent Alpine IDA-X300 Car CD/ MP3 Player Questions & Answers
3answers
Subwoofer makes a loud bass machine gun noise when powered up
Well, I have the same problem and I would think it has something to do with the RCA-connections. If I power up my head unit while I have my main fuse for the amp's removed and then replace the fuse as the head unit is already playing music (thus putting out a current through the RCA-connections) it works just fine. But if I just power up my stereo with the fuse in, my subs go all crazy. I guess it has something to do with disruptions in the rca cable. Maybe they are drawn too close to some power cables or speaker cables? Good luck!
5/23/2016 6:42:40 PM • Alpine IDA-X300... • Answered on May 23, 2016
Is there an update for the alpine ida-x300 to run
If you get the ALPINE KCX-422TR or search ebay for "12V TO 5V CHARGING FOR iPOD iPHONE" you can get a fix for your iphone cable. Basically the new iphone/ipods use 5v not 12v like the older models.
10/15/2011 9:03:08 PM • Alpine IDA-X300... • Answered on Oct 15, 2011
Picture of wire diagram
http://support.alpine-usa.com/products/documents/QG_IDA-X300.PDF
see page 26
10/15/2010 5:36:19 AM • Alpine IDA-X300... • Answered on Oct 15, 2010
When I plug in my ipod into the the AIpine get an
Are you using the KCE-422i cable included with the unit? The iPod will not work plugged into the USB port with the factory Apple cable. You need to use the silly Alpine cable.
5/31/2010 2:14:00 PM • Alpine IDA-X300... • Answered on May 31, 2010
How do i program the radio stations into my head u...
Here is a link to the owner's manual for the stereo, it should tell you there:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/500/500IDAX200.PDF
5/22/2010 4:32:08 PM • Alpine IDA-X300... • Answered on May 22, 2010
Hi i m looking to buy a face panel alpine ida-x
try pacparts.com
5/6/2010 5:22:18 PM • Alpine IDA-X300... • Answered on May 06, 2010
How do you connect the ipod to the ida-x300
The IDA-X300 has a USB jack on the back of the unit.
You can plug an iPod USB cable (just like you use to connect the iPod to the computer) into this jack, or you can attach a USB thumb drive loaded with music files.
It is not compatible with generic MP3 players other than the iPod, but you can buy an adaptor (KCA-121B Ai-NET/RCA) which will let you connect axillary inputs like MP3 player, DVD players, etc.
Does this answer your question? Feel free to use the "add comment" link if I can explain anything else.
If this helped, please be sure to hit the "thumbs-up" for me!
2/9/2010 12:29:55 PM • Alpine IDA-X300... • Answered on Feb 09, 2010
Alpine X 300 gets to a certain volume and turns
How do you have your speakers hooked up to the deck. If you have bridged any speakers to the deck, its overloading it and thats why it shuts off. Its getting too hot.
7/10/2009 7:52:28 PM • Alpine IDA-X300... • Answered on Jul 10, 2009
Wont store settings and radio stations
Make sure you have the yellow wire is hooked up to a constant source, like your head lights, if you don't those settings won't get stored.
5/19/2009 4:23:45 PM • Alpine IDA-X300... • Answered on May 19, 2009
I need a Manual for a Alpine Vie-x077 in English and also anyone know why it keeps saying the disc needs to be ejected but it won't
  1. Mechanical Issue: There might be a mechanical problem with the disc drive or the eject mechanism. It's possible that a part is jammed or not functioning correctly.
  2. Dirty or Damaged Disc: If the disc is dirty, scratched, or damaged, the player may have difficulty reading it and thus not ejecting it properly.
  3. System Error: There could be an internal error within the player's software or firmware causing it to not recognize the disc properly or to malfunction when attempting to eject it.
  4. Power Issue: Sometimes, power-related issues can affect the functionality of electronic devices. Ensure that the player is receiving adequate power and there are no loose connections.
Here are some troubleshooting steps you can try:
  • Turn off the player and then turn it back on to see if it resolves the issue.
  • Try ejecting the disc using the manual eject button (if available). This button is usually a small pinhole near the disc slot. You can insert a paperclip or a similarly sized object into the hole to manually eject the disc.
  • If possible, try using a different disc to see if the problem persists. If other discs work fine, then the issue may be with the original disc.
  • Check for any visible obstructions around the disc slot and remove them if present.
  • If none of the above steps work, you may need to contact Alpine customer support for further assistance or consider taking the player to a qualified technician for repair.
3/2/2024 3:22:33 PM • Alpine Car Audio... • Answered on Mar 02, 2024
My Alpine CDE-W235BT bluetooth has stopped working
Se o Bluetooth do seu Alpine CDE-W235BT parou de funcionar ap?s uma falha durante a atualiza??o, pode haver algumas etapas que voc? pode tentar para resolver o problema: 1. **Reinicie o Aparelho:** - Desligue o r?dio por alguns minutos e ligue-o novamente. Isso pode reiniciar o sistema e resolver problemas temporariamente. 2. **Restaurar as configura??es de f?brica:** - Consulte o manual do usu?rio para descobrir como realizar uma restaura??o das configura??es de f?brica em seu Alpine CDE-W235BT. Isso pode resolver problemas causados por configura??es incorretas. 3. **Verifique a vers?o do firmware:** - Se poss?vel, verifique a vers?o do firmware do seu Alpine CDE-W235BT. Se houver uma vers?o mais recente dispon?vel, considere atualizar novamente o firmware, seguindo rigorosamente as instru??es do fabricante. 4. **Remova Dispositivos Pareados:** - No menu Bluetooth do r?dio, remova todos os dispositivos pareados anteriormente e, em seguida, tente parar novamente. ?s vezes, problemas de conectividade podem ser resolvidos removendo e pareando novamente os dispositivos. 5. **Atualiza??es de Software:** - Verifique se h? atualiza??es de software dispon?veis para o seu Alpine CDE-W235BT no site do fabricante. Caso existam, siga atentamente as instru??es para realizar a atualiza??o. 6. **Contate o Suporte T?cnico:** - Se as solu??es acima n?o resolverem o problema, entre em contato com o suporte t?cnico da Alpine. Eles podem fornecer assist?ncia espec?fica para o seu modelo e orienta??es adicionais para resolver o problema. Lembre-se de que mexer no firmware e nas configura??es do dispositivo envolve riscos, e ? sempre recomend?vel seguir as instru??es fornecidas pelo fabricante para evitar danos permanentes ao aparelho. Se voc? n?o se sente confort?vel fazendo isso por conta pr?pria, procurar ajuda profissional pode ser uma op??o.
2/16/2024 6:59:12 PM • Alpine Car Audio... • Answered on Feb 16, 2024
Alpine tdm 7543. Is this a model that can switch from green to red lighting?
After researching, it appears that there is no direct evidence suggesting that the Alpine TDM 7543 stereo unit has the ability to switch from green to red lighting. This is an older unit and specific information can be challenging to find. Your best option to get a definitive answer may be to directly contact Alpine's customer service or refer to the original instruction manual.
1/16/2024 5:53:53 PM • Alpine Car Audio... • Answered on Jan 16, 2024
Alpine IDA-X300 Car CD/ MP3 Player Logo
23 questions posted
Top Alpine Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Alpine Car Audio & Video
Most Popular Question
update alpine ida x300 run
  • Car Audio & Video
