20 Most Recent
Harman Multimedia Harman Kardon THEBRIDGEII THE BRIDGE II DOCKING STATION f/IPOD Docking Station, Remote Control Questions & Answers
Bridge II only displays Album title
I had the same problem with my HK AVR 355 and The Bridge II.
Yours has entered manual mode by itself?! You think the bridge it did by itself but You did it.
I tell you how! I had the same problem but it's not problem but a lack of user's manual. In the automatic mode the searching through albums and artist on the on screen display is very slow. You are pushing and pushing and pushing the "menu" button. That was the problem!
Connect your bridge and ipod and turn on the AVR. Switch to The Bridge as input. It will say that you are in manual mode. Push the menu button on the AVR's remote for a few seconds. And it will turn back to automatic mode!!! That's all!
The real problem is neither of two manuals (The Bridge and AVR) tell any words about the function of holding down for seconds the menu button. Its function is to switch between manual and automatic mode!
10/5/2009 9:37:00 PM •
Harman...
Answered
on Oct 05, 2009
Harman kardon avr 4550
There is no battery to fix this issue. There is a Back Up capacitor that serves this function. Nor a DIY repair. If you require more assistance, or would like to inquire about repairing your HK, please visit my website at audioserviceclinic.com and contact me there.
12/19/2014 2:05:52 AM •
Harman...
Answered
on Dec 19, 2014
With Soundsticks II I lost
Yes, either the internal contacts to the speaker wires are broken or (most likely) the amplifier circuit has failed and you will have to replace it.
It's a complex job that only an experienced repairman should do.
9/9/2011 5:15:55 PM •
Harman...
Answered
on Sep 09, 2011
HK AVR 445 stuck in standby. Power won't stay on.
you have a blown capacitor in your receiver it controls you constant flow of electricity to keep the unit on you cant fix it without the required part so you should take it to the shop
5/15/2011 1:47:36 PM •
Harman...
Answered
on May 15, 2011
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
Audiosonic CR-06PL not changing time when following manual instructions.
Set Time Hours and Minutes: Press Time/12/24 and Alarm1/ON/OFF buttons at the same time for two seconds and it will start to blink the hour.
Press and hold the button for a fast setting or tap it briefly to increase the setting by one hour. Now set the minutes with time (press and hold) and min.
How do I set the Audiosonic clock? Set current time Press and hold the time button and simultaneously press the hour to set the hours in 24-hour mode .
