20 Most Recent Tech Solution TS-900 Calculator Questions & Answers
normally if you spill any type of liquid that would certainly affect your calculator from working- i would say that you need to have it replaced
Tech Solution... | Answered on Aug 31, 2007
Make sure there is not a key stuck in the depressed state. If so try to pull it back up and you should be set. If the machine had a liquid spill this could cause that type of error too. In which case the machine is junk.
Tech Solution... | Answered on Jun 16, 2007
The ac key is you power on key. As far as not being able to input any numbers, make sure there is not a key that is stuck down or depressed. if so try to lift is up and you should be ok. Unless there was a liquid spill. In that case, cheaper to buy a new one.
The sheet sensor may be partially blocked.
Tech Solution... | Answered on Jan 30, 2018
Tip
The ability to think logically and creatively
Techs should be able to apply a consistent, logical methodology to the resolution of computer problems. This means that even when confronted with new situation, the tech will stand a good chance of being able to resolve the problem, or at least isolate the problem area. To back up their logical thinking, techs also must be able tomake creative leaps in reasoning when the application of logic fails to produce a satisfactory resolution
on Nov 21, 2017 | Tech Solution Office Equipment &...
I have this same shredder and same thing happened to mine just 2 months after warranty is up. I called the company and told the sensor is gone and there is no way to replace. BTW mine runs in reverse but not forward.
Tech Solution... | Answered on Sep 10, 2013
Tech Solution TS-900 Calculator Logo
Popular Tags
4 questions posted
Top Tech Solution Office Equipment & Supplies Experts
Damen Wong
Damen Wong
Steve Allison
Steve Allison
Jim Keysor
Are you a Tech Solution Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Tech Solution Office Equipment & Supplies
Most Popular Question
off button doesnt turn
  • Office Equipment & Supplies
