20 Most Recent BenQ SP820 Projector Questions & Answers
0answers
Doesn't stay on
Be the first to answer 3/18/2017 5:30:05 AM • BenQ SP820... • Posted on Mar 18, 2017Be the first to answer
2answers
Ballast error status - lamp voltage too high
You need to replace the balast as the voltages are buringing the bulb out and this is caused by a balast that is bad. The baslast is what the bulb connects to this has a sensor on it that relays voltages and heat back to the main control unit. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
1/25/2015 11:34:43 PM • BenQ SP820... • Answered on Jan 25, 2015
0answers
My lamp is not igniting??! how do i fix??
Hi Carl, It sounds like you may have an issue with either the bulb or power supply. In either case, you will need the help of a professional service center. Feel free to send me an e-mail at [email protected] and I can have one of our techs contact you. Home
1/24/2014 12:46:09 AM • BenQ SP820... • Answered on Jan 24, 2014
0answers
0answers
SP820 lamp never comes on. It
Hi.
18 blinks is not a fault code. The LED probably starts blinking because the controller board is faulty, and stops after 18 times because it dies always at the same time. Problem is likely main controller board, you can try testing the board at component level. Check connectors a shorted connector is a common fault that may have unforeseen effects. Test PSU voltages just in case, wrong voltage to controller may fry it and may result in no error code.
8/8/2011 6:55:45 PM • BenQ SP820... • Answered on Aug 08, 2011
I have a Benq sp820.
The processor is locked up, in the unit and you need to unplug it from wall for 40Min., and it will reset back to normal.
2/26/2011 5:16:46 PM • BenQ SP820... • Answered on Feb 26, 2011
Hi, I have an SP820. When I make a presentation
dear user ,
your projector needs service..i think there is dust in your projector..kindly check the filter
2/3/2011 11:24:46 AM • BenQ SP820... • Answered on Feb 03, 2011
Hello, i need Benq 5000 series scanner power adapters which place is the comfort
eBay, Ali Express or Amazon. https://www.google.com/search?q=Benq+5000+series+scanner+power+adapters
AC Adapter for BenQ 5560 5000S Scanner Power Supply ...
eBay https://www.ebay.com > ... > Monitor Power Supplies AC Adapter for BenQ 5560 5000S Scanner Power Supply Charger 16V ; Quantity. 4 available ; Item Number. 334789927109 ; Brand. Unbranded ; Type. AC/Standard ; Accurate ... US$13.00 · ‎ In stock
16v 1a Ac Adapter Wall Charger For Benq 5560 5000s ...
AliExpress https://m.aliexpress.com > ... 100% Brand New AC Power Adapter Specifications: Input(AC): 100-240V,50 - 60Hz Output(DC): 16V 1A (use for 0.9A ). DC CABLE LENGTH: 90CM. US$10.98 · ‎ In stock ..
2/19/2024 5:49:33 PM • BenQ Office... • Answered on Feb 19, 2024
BenQ SP820 Projector Logo
21 questions posted
Top BenQ Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • BenQ Office Equipment & Supplies
Most Popular Question
ballast error status lamp voltage high
  • Office Equipment & Supplies
