Troubleshooting & Support
Hot Topics:
- magnavox mrd510
- need remote...
- surround sound
- need remote...
- not speakers...
- remote
- CODES
- dvd home...
- user manual
- hdmi input
- mrd510
- theater system...
- magnavox mrd...
- d5 cod bledu
- speakers work
- hdmi
- mrd 200
- home theater
- surround sound...
- mrd510 remote...
- speakers...
- Receiver won...
- nec multisync...
- home
- remote control
- reset unit
- owners manual
- mr
- audio vhs...
- dfr 1600
- View All »
Problems & Solutions
why is the system shutting itself off?
Generally speaking, an amp protects itself from heat, shorts and overloads. Overloads can be from excessive periods of high output and...
the difference between (+) and (-) on my speaker
The one with the black stripe is the negative. Cheers!
Lost installation guide for Magnavox MRD 510 Home...
Download MRD-210 User Manual as it might help you to hook up video cables properly. Connections between Tv and Homer theater is not proper...
codes
Where the code is listed as (### ###) the first one is for the DVD and the second is for the audio. Otherwise just the one cod operates both...
i have a magnivox home theater model #mrd510 all
Check the source cable is ok, replace with another if possible. Also make sure the source is not putting out a standard the HTS does not...
how do I make all speakers to work?
check you settings . make sure you volums are up for each speaker, and see if you delay speaker settings are messed up , if that dont work...
I have a magnavox MRD510... I openned it brand new
take it back
when i power it on,it flickers then shuts
Serious power issue. Generally speaking, an amp protects itself from heat, shorts and overloads. Overloads can be from excessive periods of...
My magnavox suround system works great when I view
That would depend on how your cable box audio is routed to the MRD. I can't find a clear readout on its audio INPUT capabilities. If it...
any time we turn up the volume...it sounds like
when u say fly away do u mean vibrates A LOT? A lot of different programmes require different sound settings. have u tried to adjust the...
Magnavox MRD-510- when I plug
Protect mode will kick in whenever a fault is detected. You get the unit not powering up, and sometimes you hear a clicking noise, that is...
Suddenly lost sound
On my system, there a button to turn off the amplifier and an additional button for silencing the speakers. Did the speaker button get...
hey ,,i bought new philips dsp 2500 mms system.
audio out from the TV into the audio in/ Aux on the HTS2500. Back connectors a AC MAINS~ Connects to the power supply. b SPEAKERS Connects...
I need to find the
Then you need something like that http://en.wikipedia.org/wiki/TV_aerial_plug $5 at every tv shop.
will my home cinema also
Yes, but only if the tv has an digital audio output. If that is the case connect that to the home theater and mute the speakers from the tv...
Unsolved Problems
when i turn volume up it sounds like the fan gets
when i turn volume up it sounds like the fan gets really loud. how can i fix that?
i can not set up
i can not set up the tunner lost my manuel
won't put out in but
won't put out in but 2 speakers
I have lost the remote
I have lost the remote for my Magnavox MRD510 system and am unable to program a phillips universal remote...
I am connecting the Magnavox
I am connecting the Magnavox MRD 510 to my flat screen tv.... I am not sure were the other unmarked wires ... one is...
I need the code for
I need the code for the magnavox MRD510 to set my universal remote, please help! I'm tired of getting in and out of...
Need to acquire a
Need to acquire a Philips Magnavox MRD510/17 Theater System Remote control
Upload a manual for Philips Magnavox MRD510/17 Theater System
Specifications
TopKey Features
Full Product Name:Philips Magnavox MRD510/17 Theater System
Number of Speakers:5 Speakers and Subwoofer
Playable Disk Types:DVD-RW
Playable Disk Types:CD-R
Playable Disk Types:CD-RW
Playable Disk Types:DVD Video
Playable Disk Types:CD (Audio)
Playable Disk Types:VCD
Playable Disk Types:Picture CD
Playable Disk Types:DVD Audio
Playable File Formats:MP3
Playable File Formats:JPEG
Playable File Formats:MPEG2
Playable File Formats:MPEG1
Front Speaker:1 Way
Included Components :DVD Player
Included Components :Radio Tuner
DVD
TV Resolutions:720p (750p)
TV Resolutions:1080i (1125i)
Number of Discs :5
Progressive Scan :With Progressive Scan
Built-in TV Tuner :NTSC
Tuner
Tuner Presets:20
What's your problem?
Fix-O-Meter
2,354
2,354 people have viewed this product
- 34 people asked about this product.
- 11 people found solutions for this product.
- 2 people have added this product.
DVD wont play...
Turntable low...
Denon...
