20 Most Recent
Texas Instruments TI-Nspire Graphic Calculator Questions & Answers
How to integrate xsinx between -1 and 2 on
To do this on the TI NSpire:
- Press [HOME] [1]
Press [CATALOG] [1] [I] and scroll down until the integral symbol or integral( function is located. Press [ENTER] on either function.
- Input: x sin x, x, -1, 3
- Press [ENTER].
7/23/2018 11:47:21 AM •
Texas...
Answered
on Jul 23, 2018
What does "domain error an argument must be in a
The expression a function acts on (i.e. what is inside the function) is called its argument. The arguments of some functions such as y=ax, y=ax^2 can have any real value. However some functions have arguments that must be in a specified domain: they are restricted to some specified intervals. For example y=square root (x) can act on any positive value, but if you feed it a negative value it is out of the correct domain.
4/15/2018 9:59:13 PM •
Texas...
Answered
on Apr 15, 2018
I get -0.017453 as an answer to derivative of cos
The differentiation rules for trigonometric functions you have been taught (ex: derivative of sin(x) is cos(x) ) are correct if the angle unit is in radians. If you use any other angle units (ex: degrees, grads) there will be a conversion factor :derivative of sin(ax) with respect to x is a.cos(ax).
Hope that helps
4/15/2018 9:44:18 PM •
Texas...
Answered
on Apr 15, 2018
How can i tell if the battery is charging
Turn the calculator ON, press Settings, It will show you an icon for a battery with a broken arrow (Zap). It will also show the percentage of charge.
8/29/2014 12:02:44 AM •
Texas...
Answered
on Aug 29, 2014
TI-Nspire CX water damage
Too bad you cannot call Qualinet, because they only do houses. Just joking. Let it dry and try later. I might work again.
8/28/2014 11:14:41 PM •
Texas...
Answered
on Aug 28, 2014
HOW DO YOU KNOW WHEN YOUR BATTERY IS DEAD
You check the calculator settings. It will show you the percentage of battery energy. If the calculator refuses to turn on, the battery are dead.
8/27/2014 3:42:37 AM •
Texas...
Answered
on Aug 27, 2014
Simplify fraction
58165/2165 is already in its simplest, most reduced form.
6/12/2014 3:10:00 PM •
Texas...
Answered
on Jun 12, 2014
