20 Most Recent
Fasco K101 Wall Mounted Panel Heater Questions & Answers
I have Model A2540T manuf.
hello,
what you will have to do if you need the temperature of the room should go better then what it;s firs of all check on the thermostat time programming,since the you have note the heater degree to spot function ,but if after all this the problem remain same then you can then think of servicing the thermostat or replacement.
thank for visiting fixya.y
Totaline p474 1050 thermostat reset
there is no rest. Item used 24VAC from hvac to power it . If 24VAC from hvac is missing thermostat will not power up and hvac will not work. You will need to call for service.
