20 Most Recent
General Electric GE 7 0 Cu Ft Super Capacity Electric Dryer - DCVH680EJ / DCVH680EJMR - colo Questions & Answers
A few days ago our tumble dryer begun to make a
that could be anything you just have to unplug the dryer and get in there and see what happened,the belt pulley could have failed and jamming up the belt,first off does the dryer start?if so and the drum isn't spinning then the belt could be broke but this says it's a g.e. dryer so this has a safety switch in it that won't let the dryer run if the belt breaks,also g.e. has a rear bearing that fails,did you hear any sounds before like metal on metal,this could be alot of things,there's a front bulkhead with glides on it,i've seen the drum cut through the front of the dryer before, if you write back send the brand name and model number and anything else you heard before or take it apart and see what's up.if the dryer has alot going on with it don't buy another g.e. dryer get a whirlpool.
Indesit is70c ..the dryer heats up but does not dry the clothes
Hi Kristina. Try cleaning out your dryer vent line. Depending on how it's installed, sometimes it can get clogged at the discharge screen outside or if the line is draped under a house or a mobile home.It can develope a belly or multiple bellies depending how it was installed. These will trap the humid air discharge coming from the dryer and the condensation will accumulate in the line restricting the discharge air and tripping the safety limit switches. you can use a shop vac to clean the line but be careful,if the vent is old it can become brittle and crack easily. If the line is in question I recommend placing the hose on the discharge side of the vacuum and blow it through. It may make a little mess but far easier then replacing the line or worse the dryer.
Remote not working at install Casa Turbina DC 60
Do you have a phone with a front facing selfie camera? Face the front of the remote at the camera and press a button. You should see a flash. If you don't, the batteries need changing or the remote has failed.
4/21/2024 12:53:31 AM •
Dryers
Answered
on Apr 21, 2024
