20 Most Recent Weber Spirit SP-310 Propane Grill Questions & Answers
Did you check round the burner control knobs
Weber Spirit... | Answered on Apr 13, 2017
The metal contact inside the push button ignitor is probably sticking.
Weber Spirit... | Answered on Apr 30, 2015
Hi, Kirk. The positive end of the battery should face you, when you install it. Before you rush out to buy a new ignition module, check all the wiring from the module to to each spark ignite. You want to make sure that all wiring is in intact, that the ground wire for the module is attached to the grill frame and that the spark igniters are clean & free of grease.
If you find you need to replace the igniter module, you can find it at the following link.
http://www.appliancefactoryparts.com/search/partinfo.php?partsID=496283&modelsID=124200
Hope this helps you. Don't forget you can match light the burners if necessary, until the igniter module is replaced. Happy Grilling!!
Weber Spirit... | Answered on Apr 18, 2015
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Weber Spirit... | Answered on Aug 04, 2014
try taking the burners out and soak them in some clr grease from cooking can clog them also check the orfices are not blocked , if you do hot have clr try blowing them out with a air line .
Weber Spirit... | Answered on Sep 24, 2011
turn off gas at tank remove hose let it deforst , open all burners on bbq run out gas in line , turn off burners, reconnect tank turn on slow , check hose for leaks with washing up liqued and water mix make bubbles with this mix and brush over joints this will prove if you have a gas leak (hence the frosting ) if this is good no leak then you should be able to light burners , if this leaks then it could be a new hose.
Burners could be blocked remove and clean out burners , with air line or a vac on blow you could soak them in C L R , you could also check the orffices are not block , check gas line for blockage , try some this it may help you .
Weber Spirit... | Answered on Sep 16, 2011
Jay, to solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!!
Thanks for choosing FixYa.
Weber Spirit... | Answered on Sep 10, 2011
Since there is some dismantling of the grill required, to remove the burners. I have included a link to the Owner's Manual for you grill.You can download and print it for future reference.
http://help.weber.com/manuals/pdf_files_2011/Gas/Spirit%20ES%20Series%202007newer/OwnersGuides/Spirit_210310_NG_OwnersGuide_89527_030308.pdf
Hope this helped you and Happy Grilling!! Thanks for choosing FixYa.
Weber Spirit... | Answered on Aug 14, 2011
Weber Spirit SP-310 Propane Grill Logo
36 questions posted
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
View Most Popular
Weber Grilling
  • Weber Grilling
Most Popular Question
low flame no heat
  • Grilling
