20 Most Recent Masterbuilt 20070206 Smoker Questions & Answers
I just bought a new Masterbuilt Smoker by default two weeks ago I borrowed a friend’s to smoke about 30lb. of Salmon to then can. Ran the smoker every day for three day. ON my last batch the heating element would not work. Talk about Frustrated! The Smoker was only 2 yrs. old.
Knowing I borrowed I felt I had to replace. So online to Cabelas and I ordered my buddy a new smoker and had it shipped. I then found this website... GOT TO LOVE the internet. I saw many other people had the same problem. Found an Answer...
The Problem was one of the connector to the heating element was poor quality and if you don't clean your smoker on a regular basis. The heat and moister caused the small copper connector to corrode and the wire to come loose. I took a wood chisel and cut off all the rivets on the back. I was then able to pull the back off with no damage and access the small box in the lower back. I found the connector. Went to the hardware store and bought a replacement for .75 cents. A pair of wire crimpers and the problem was fixed. I also bought ½ inch Sheet metal screws to secure the back it was good as new. So I returned the smoker to my buddy and kept the new one. When it arrived I saw Masterbuilt has since fixed the problem and provided an access panel to the element and connectors.
Mike in Alaska
PSU313@yahoo.com
Masterbuilt... | Answered on Dec 30, 2016
Does that smoker have a "high limit" snap switch inside? If it does, that's the likely cause - try replacing it with a correctly-rated one.
Masterbuilt... | Answered on Nov 05, 2013
Unfortunately no. What temperatures are you trying to reach. Most smoking of meat is done at 225-250. What is the maximum you can obtain? Keeping the unit out of the wind and cold, better insulation, stopping any leaks, is about the only way to do it.
Masterbuilt... | Answered on Nov 10, 2010
Wow, someone's not happy!!
Masterbuilt... | Answered on Aug 20, 2010
I found the online manual for the 20070206 smoker and it has the replacement parts list and shows the element has part # 990050051.
Go to this website and see if you can order it or call them.
http://www.masterbuilt.com/contact.html
The parts list is on page 3 at this link.
http://www.masterbuilt.com/pdf/manuals/Smokehouse%20models%2020070206,%2020070106.pdf
Masterbuilt... | Answered on May 18, 2010
ck the power / if 230 / ck both legs .. turn power off and then back on . . may have hi limit / most do and may be restable .. .. if one time replace it . . ope this helps mm
Masterbuilt... | Answered on Dec 07, 2009
I get mine from Grillparts.com....I believe they are here in Floriyda.You might search around in the Yellow Pages for somebody close to you
Masterbuilt... | Answered on Mar 27, 2009
Masterbuilt 20070206 Smoker Logo
18 questions posted
Top Masterbuilt Grilling Experts
Ted-L
Level 1 Expert
Paul Carew
Simon Flummox
Simon Flummox
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
View Most Popular
  • Masterbuilt Grilling
Most Popular Question
masterbuilt electric smoker stopped
  • Grilling
