20 Most Recent Brinkmann Charmglow 810-7400-S Propane Grill Questions & Answers
Regulator freezing up
1. Are you using a portable LP cylinder? LP Regulators freeze up when the liquid part is the propane is flowing through the regulator this is caused by an overfilling of the propane tank. 2. If the BTU capacity of the regulator is not high enough to cover the BTUs of your grill, the regulator is working too hard and potentially pulling liquid (not vapor as it should) I would suggest calculating the BTUs of your grill and looking to see what the capacity of the regulator you are using. You can also read this about regulators LP Gas Regulators 101
1/9/2018 2:04:02 PM • Brinkmann... • Answered on Jan 09, 2018
Last summer closed up grill had no problems..today not working
unhook the tank and hook it up again being sure that the regulator is right side u p.
these new grills have a safety valve that often partially closes and causes problems.
5/25/2014 6:45:57 PM • Brinkmann... • Answered on May 25, 2014
2answers
The flow gas coming from the burner is very slow.
It could be a defective LP gas regulator or a restriction somewhere in the gas line for the bbq. This can also happen if the propane tank is overfilled.
First make sure that the LP tank is not overfilled. If you open the bleeder hole on the tank(small screw next to the valve) there should be no liquids coming out. If liquid propane is coming out then the tank is overfilled. Keep the bleeder screw loose until the liquid disappears then tighten. Re-connect the tank and see if that fixes the problem.
Then inspect all the gas lines on the bbq. Make sure that there are no kinks or crushed lines.
Then take a look at the gas regulator. Try turning on all the burners then give the regulator a couple good taps on the housing with something solid. See if the burner changes size. If it does and then goes back down it could be the gas regulator. Also take a look at the regulator housing. There should be a very small hole on the housing and it might be labled "vent". Make sure that this little hole is not plugged with any debris or that can cause a low pressure problem. You can use a sewing needle to gently poke out the hole. You will know if it worked because the burners will become much higher. And you could also try disconnecting the hose and regulator assembly from the bbq then turn on the LP tank slowly with the regulator connected. You should get plenty of gas flow from the end of the hose. Then use your hand to block and release the flow a couple times to try and clear any debris that might stuck in the regulator.BE VERY CAREFUL DOING THIS!!! MAKE SURE YOU ARE CLEAR OF ANY SOURCES OF IGNITION BEFORE TRYING TO CLEAR THE REGULATOR. Then reconnect the hose regulator and tank to see if the problem is fixed. If you are getting very low flow from the hose with the regulator disconnected then it is probably a defective regulator. They are pretty standard and you can purchase a new LP hose and regulator assembly from most home improvement stores.
If the regulator checks out good then I would think that there is a restriction in the main gas line for the bbq after the regulator. You will need you dis-assemble the main line and blow it out with some compressed air to clear the restriction.
1/8/2014 1:38:41 AM • Brinkmann... • Answered on Jan 08, 2014
REPLACED OLD BURNERS WITH NEW GETTING POPPING OF GAS AND GOING OFF AND ON
you could try adjusting the air mix at the front of the burners seif that helps.
4/22/2012 1:22:58 PM • Brinkmann... • Answered on Apr 22, 2012
Popping of gas from new burners and going off and on
check to see if there is any packing in the burners , they could be just not in the right postion or the air mix could need adjusting .
4/21/2012 12:11:58 PM • Brinkmann... • Answered on Apr 21, 2012
2answers
Charmglow 810-7400-S Propane Grill: have a charmglow patio heater, the pilot comes on ...
I have a Charmglow Patio Heater Model SRPH02, it needed a Thermocouple and searching the net was hard to find an ariginal part, but here it is, call 1-866-814-0585 $3.95 +6.00 shipping the original part.
6/17/2011 7:47:28 PM • Brinkmann... • Answered on Jun 17, 2011
We have a charmglow grill.
Depending on how the the grill's thermostat reads (Most go to 600 degrees). So, medium would be 300 -350 degrees. Keep in mind, all the temperatures are based on drilling with the hood closed (like your kitchen oven). Once it's opened the temperature will drop significantly
I assume from your question, that you are trying to bake something on the grill. Which is fine, with a little practice, you can bake a cake or bread on the grill, as well as a ham. But, a ham takes a little bit of expertise.
Happy Grilling!
2/19/2011 10:11:36 PM • Brinkmann... • Answered on Feb 19, 2011
I have had my Charmglow grill for about 4 years
Sounds like a classic symptom caused by a failing regulator. Replace the regulator, easy to do and not very expensive. Turn off the tank and unscrew the regulator from the tank. Remove the tank and use a 3/4" wrench to remove the hose from the manifold. Do the reverse to install the new regulator. The fitting should be a 3/8" flare, so you do not have to tape it, just snug it on good. Check for leaks using soapy water.
11/14/2010 2:27:14 AM • Brinkmann... • Answered on Nov 14, 2010
The side burner does not look like the one in the
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
9/6/2010 12:03:18 PM • Brinkmann... • Answered on Sep 06, 2010
The flame is yellow and
close your vents on your burners
8/19/2010 5:52:18 PM • Brinkmann... • Answered on Aug 19, 2010
I can't get gas to go from the tank to the
Replace the hose and regulator, easy to do and inexpensive.
7/13/2010 4:00:02 PM • Brinkmann... • Answered on Jul 13, 2010
My charmglow is experiencing low gas flow. What
If is an LP, the regulator could be bad, easy to replace and not very expensive. Try a new regulator and hose first. If it is a NG grill, there still may be a regulator on it, not as easy to change out, but not very expensive. Try these things, if they don't work, let me know.
7/12/2010 2:42:17 AM • Brinkmann... • Answered on Jul 12, 2010
How does one replace charmglow burner tubes on my
most of it yes to get too, the parts you wish to replace
6/23/2010 11:09:28 PM • Brinkmann... • Answered on Jun 23, 2010
Low flame burning on CharmGlow 4-burner gas grill,
check burners are not bolcked check orffice is not blocked also check reg is giving right pressure
5/17/2010 2:05:50 PM • Brinkmann... • Answered on May 17, 2010
The burners do not get a full flame anyomre, nor
you may have spider web in the burner ... disassemble and blow it out with canned air or a air compressor ...
5/2/2010 3:10:58 AM • Brinkmann... • Answered on May 02, 2010
Charbroil gas grill will not ignite... needs repai...
may just need new battery in the button
5/1/2010 10:12:35 AM • Brinkmann... • Answered on May 01, 2010
Bought new ignitor still will not put spark to
did you change the battery and it could be the starter
4/28/2010 1:53:51 AM • Brinkmann... • Answered on Apr 28, 2010
I can't turn two of the gas controls. my gas grill
Controls have seized up. Take off knob and try pliers, go slow so you don't break anything. This might free up. If not replace controls.
3/26/2010 2:59:59 PM • Brinkmann... • Answered on Mar 26, 2010
I can not get any gas pressure in main burners or
Look for spider webs in the venturi tubes, check the orfices or it could be faulty controls. Verify the tank working properly by trying on another grill.
Eric
1/24/2010 10:22:37 PM • Brinkmann... • Answered on Jan 24, 2010
Brinkmann Charmglow 810-7400-S  Propane Grill Logo
42 questions posted
Top Brinkmann Grilling Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
View Most Popular
Brinkmann Grilling
  • Brinkmann Grilling
Most Popular Question
charmglow 810 7400 s propane grill have
  • Grilling
