20 Most Recent Brinkmann 810-8410-S Stainless Steel Propane Grill Questions & Answers
Victor, are you sure you're getting gas to the burners after installing the new tank? You can try match lighting them to make sure. But, I suspect, that it's the installation of the new tank, that's causing the problem.
To test my theory, tune the tank valve OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Ope the tank valve VERY, VERY SLOWLY (Slow motion, slow). Once the valve is fully open, try lighting the burner that's farthest from the tank first and turn it to high. Did the burner light and does the flame height look correct? If so, light the remaining 3 main burners the same way. Did those burners light and the flame heights looks correct? If, so you solved the problem. Remember to always turn the tank valve ON VERY, VERY SLOWLY.
Hope this helped you solve the problem. Happy Grilling.
Brinkmann... | Answered on May 06, 2014
try removing the eyes of the burners and make sure there is no dirt inside of it...that might help
Brinkmann... | Answered on Sep 19, 2013
If it corroded off or broke you'll be better off getting a butane grill lighter and doing it manually that way. Then, just food gets cooked. It may just be a loose screw...you need to pull off the grate and check it out.
Brinkmann... | Answered on Jul 21, 2012
Please see previous reply with Owners Manual link.
Brinkmann... | Answered on May 10, 2012
The best thing you can do it the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!! Thanks for choosing FixYa.
Brinkmann... | Answered on Sep 23, 2011
I am not sure, but I think the Brinkman uses the ignitor to light one burner and the other burners light after the first one allowing the flame to "crossover".
Gary
Brinkmann... | Answered on Sep 18, 2011
To solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
Brinkmann... | Answered on Sep 04, 2011
Brinkmann 810-8410-S Stainless Steel Propane Grill Logo
57 questions posted
Top Brinkmann Grilling Experts
Paul Carew
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
View Most Popular
Brinkmann Grilling
  • Brinkmann Grilling
Most Popular Question
second tank ve tried lights but doesnt
  • Grilling
