20 Most Recent Navigator Evesham Nav-Cam 7000 GPS Receiver Questions & Answers
you can try this memory card recovery software named asoftech data recovery software. You can see
http://www.asoftech.com/adr/
It tells the steps how to perform data recovery.
If above does not work, you may have to format the memory card (use quick format), and then use above mentioned software to scan again the memory card and recover your files.
Navigator... | Answered on Jun 29, 2016
I would have thought any dealer selling garmin product would be able to supply you with a lead.
To download maps:
http://btjunkie.org/search?q=garmin+maps
Navigator... | Answered on Aug 12, 2015
I lost my SD/MMC Card for my Navigator Evesham Nav-Cam 7000 GPS Receiver I vant to get a nother one or dowload Nav-Cam 7000
lukonbokiyedi@yahoo.co.uk
Navigator... | Answered on May 08, 2013
can i darken my screen ..its to light .
Navigator... | Answered on Nov 30, 2011
Need free download software to get it working.
Navigator... | Answered on Mar 18, 2011
Amazon or E-bay has them.
Navigator... | Answered on Mar 08, 2011
Unfortunately its an old model no updates are available.
However you maybe able to get a little for it on ebay.
Please dont forget to vote if you liked my answer
many thanks
Navigator... | Answered on Feb 13, 2011
My Evesham nav-cam 7000 model ps1025 is showing the following:-fatal application error Application Mobile Navigator.exe has performed an illegal operation and will shut down.If the problem persists contact the program vendor.Program 0xc0000005 Address 000d026c.What can i do to remedy and get a cd disc for it?
Navigator... | Answered on Feb 10, 2011
how long have you been using this Unit? The problem is either from the charger or the battery.
A charger can sometimes charge the battery, but might not give it full charge and this can cause the battery not to hold charge.
Also, the battery cell might be weak, and this can also not make the it hold charge.
You will have to purchase another battery. But before you do so, look for someone (family or friend) that uses this type of unit. Test the person's battery with your unit and if it works well, then it means you are free to buy another battery without any problems. Test the charger as well.
The battery is mostly the cause of the problem, but the charger also, has to be tested for clarity.
I hope you understand the above.
Good luck.
Navigator... | Answered on Feb 02, 2011
you need to open satelite tracking from menu
Navigator... | Answered on Nov 28, 2010
Sorry to disappoint you, but you won't find them.
SatNav mapping costs a lot to produce. The publishers only have a limited lifespan before they're out of date there's not much time to recoup the initial investment, make a profit, and generate seed-money for the next map. As a result, nobody offers these maps for free.
You might find illegal downloads for some SatNav brands, but almost without exception they'll be at least as out-dated as your current maps. You certainly won't find any for your model though: it's not a major brand and Evesham simply doesn't offer map updates for the Nav-Cam 7000.
If you want to update your maps, you only have one option: buy a new SatNav. Given how clunky and awkward your current model is and the almost universally bad reviews it received you may wish to consider a different brand next time.
Sorry this is not the answer you were hoping for but as The Rolling Stones once sang, "you can't always get what you want".
Navigator... | Answered on Sep 22, 2010
if u mean update then u must go to the manufacturers support web site and see if any maps software has been released, then you must purchase the right to download and use it.
Navigator... | Answered on Sep 15, 2010
CHEK THE SWITCH THET DISCONNECT THE BATERRY IF IT ON THE SWITCH IS LOCATED CLOSE TO RESET BUTTON ON YOUR RIGHT
Navigator... | Answered on Aug 27, 2010
yes i have the sd card with maps it will cost just 35$ make payement thrue paypal in to this email : <a href="mailto:valbonakavazi@yahoo.com">valbonakavazi@yahoo.com</a> send me your address i will mail it to asap
I couldn't find anything but bad news about this unit, so I can see why you're having a problem. The only thing you could probably do is use an external antenna. Read the following review, someone else had your problem and it was an athermic windshield blocking the signal. Here's discussion #3:
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=58257#334785
Here's some other discussions on the main page:
http://boardreader.com/thread/newbee_needs_help_with_evesham_nav_cam_6_9amX18y9.html
Here's the bad reviews:
http://reviews.gpsfaq.com/about.aspx?detail=navcam7000
An external antenna and/or amplifier might be your only hope.
Good luck, and hope this helps.
Navigator... | Answered on Aug 10, 2010
The 6400 is 3.6 inches wide. I did find this product that opens up to 4.5 inches. It should work as a replacement:
http://www.wolfcamera.com/product/EP44002734.htm
Navigator... | Answered on Jul 27, 2010
Navigator Evesham Nav-Cam 7000 GPS Receiver Logo
92 questions posted
Top Navigator GPS Experts
Tom Chichester
johnny rebel
ray gallant
Are you a Navigator GPS Expert? Answer questions, earn points and help others
View Most Popular
Navigator GPS
  • Navigator GPS
Most Popular Question
all any chance
  • GPS
