20 Most Recent Boss Rc 50 Questions & Answers
Perhaps your computer's sound card is unable to play back at the bit rate and kHz you are recording at on your (mobile?) recorder. I'm not familiar with the RC-50 but if you are recording at 24 bit for example and your computer's sound card is only able to play back at 16 bit it may not reprosuce any sound. Usually you will get an error saying so. Have you tried different playback software?
Boss Rc 50 | Answered on Dec 19, 2017
XLR inputs often have a pad (attenuator) that is switchable for signal level.
Boss Rc 50 | Answered on May 24, 2017
You can make a backup on your pc and load back Default settings or restore to default settings. Normally you should have I quote ' with up to 49 minutes of mono recording time (or 24 minutes in stereo), the RC-50 can function as a song recorder as well as a looper'
I have the RC300 which has 3 hrs recording time. But when i reach the limit. I make a backup and load back in a initial default setup which I have downloaded somewhere. But you can also restore to default from the unit itself. Hope this helps
Boss Rc 50 | Answered on Apr 21, 2017
Ok, solved this problem by visiting roland U.S. site as the help offered in this country is useless. The instructions given by email would not have worked even after the update was installed. Luckily, there are instructions that come with the download. If you have same problem as me go to http://www.rolandus.com/products/productdetails.php?ProductId=772&tab=downloads&skip=true
and update the opperating system on the RC-50 to RC-50 System Update Version 1.01.
Then hold loop sync and phrase 2 button (think it was phrase 2) to change it to sound priority mode. Then it will play back correctly what you recorded on the first loop, rather than missing the first beat.
Am v.happy I have found this, as after much searching I can't find any other loopers out there that offer 3 seperate loop tracks and the ability to switch between them effectively. Plus, it's a very convenient size, better than a load of rackmounted stuff to haul around.
However.....
Another problem..
When hitting the reverse switch ( I assigned both external footswitch and the onboard Tempo pedal to reverse) the change is not instanteaneous. There is a second or so delay before it plays in reverse. Not a problem for most, I suppose, but I have a piece that switches rythmicaly between playing forward and reverse which means hitting a pedal in time and reverse/forwards changing immediately. I think they could do with another software update to solve this. Now I have to keep room in my enormous pedal board for the old rc-20, as that does the reverse as it should - when you hit the flippin switch!
Boss Rc 50 | Answered on Oct 07, 2015
Likely the switch contacts for that pedal have failed. You will probably have to get it repaired. Stomping on the pedals is a good way to damage them, but the switches are often marginally designed anyway...
If you can access the switch you could try getting some CRC226 available at Home Depot in the electrical department into the switch, but often the internal parts of switches fail.
Boss Rc 50 | Answered on Feb 25, 2015
This could POSSIBLY be done using an external source generating a MIDI sync clock fed to both.
Hi I just got a RC 50 and I face the same problem but looking the content of the data in the Roland folder (after you connect the USB) , I notice the format of the label of each sound's and I understood the problem. So , here it is . Before you connect to USB , you have to choose a patch , let say n.16 OK, now the audio file that you want to import into the data folder must be named in this way "016_1.WAV" ,the 16 refer to the patch number and 1 is the phrase number (if you want to put the audio file into the phrase 1 ,or 2 if 2 ecc.) now disconnect the USB .At this point you just have to increase or decrease the patch number just one time and go back to 16 (it has to refresh the patch info) and you'll find your audio file ready to use in whatever phrase you put it.
have fun
Paolo
Boss Rc 50 | Answered on Feb 03, 2015
Its electronic volume control section circuit has the fault. This is not a user repairable one. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Boss Rc 50 | Answered on Jul 02, 2014
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box.
Boss Rc 50 | Answered on Jun 08, 2014
Try doing a factory reset by following the instructions in the manual. It's the quickest and easiest way to "clean the slate" and only requires a few simple steps.
Boss Rc 50 | Answered on Jan 08, 2014
Has the unit ever had another ac adapter plugged into it?
Boss Rc 50 | Answered on Mar 06, 2013
You are probably fortunate that more damage was not done.
Open the unit and you will likely find a protective diode at the input and either a fuse or that a circuit trace has been blown. Replace whatever is not conducting the power from the power jack to the rest of the circuitry. The diode is probably OK as usually the battery power is across it when the battery is used.
Boss Rc 50 | Answered on Jan 07, 2013
http://www.roland.com/support/article/index.cfm?q=manuals&p=RC-50
I tried to look at this and get the valuable information but it requires a few steps. This is a link for the product manual, what you are looking for is on page 20 I think
Boss Rc 50 | Answered on May 21, 2012
dirty dirty dirty
give the knob a ********
can of compressed air should do the ttrick remember to remove knob if posable
Boss Rc 50 | Answered on Jan 15, 2012
Boss Rc 50 Logo
54 questions posted
Top Boss Music Experts
Michial Gueffroy
Vito Vacirca Jr.
shaun taylor
Are you a Boss Music Expert? Answer questions, earn points and help others
View Most Popular
Boss Music
  • Boss Music
Most Popular Question
im trying connect two
  • Music
