20 Most Recent
XO Vision XOD1735 Car DVD Player Questions & Answers
Help me with back up camera for xo vision xod1740bt
I am just giving a suggestion. I too need to know how to wire this. From what you posted it sounds like you hooked the wire to a constant +12v that is always on. Forgive me if I am wrong. Anyway, Did you connect this wire to rear reverse light power. I think from what you say it is supposed to be connected to the positive side of that light. If this solves your problem can you PLEASE let me know the full details of everything else you hooked up on the circuit to make the backup work. For instance what is the label of the orange wire. TIA.
7/10/2018 10:50:02 AM •
XO Vision...
Answered
on Jul 10, 2018
XOvision In-Dash DVD/CD
i went throughthe same issue. trust me, svae yourself the headache and pay a professional to install it.
10/5/2017 6:56:55 PM •
XO Vision...
Answered
on Oct 05, 2017
Chevy trailblazer dvd player has sound but no
since the outputs from dvd player are all separate , 1st id look for a plug out or missing from both the display and the player (even if in same housing ) , then id move onto substitution (use small tv run on ext cord from house) as a means to figure out if its the display or player , both can be bought new from gm but you'll need to figure out what one to buy 1st
also in mobile players ,there is a feature that video is muted if car is in drive and not parked on some models b sure this is not yours
9/16/2015 11:57:42 PM •
XO Vision...
Answered
on Sep 16, 2015
Installed reverse camera to Eonon
i had the same problem with my talon today, all you need to do is get another wire , connect one end to the 12v(red)backup tail light wire and connect the other end to ur dvd player and put it one the wire that is to be connected to the 12v for the revarse camera the wire should be orange but urs might be a different color.
5/17/2013 10:58:48 PM •
XO Vision...
Answered
on May 17, 2013
Amp wont turn on
Your stereo has 2 blue or 1 will b blue with white. One will supply power to a power antenna which will only have power on radio mode not cd do check wires with test light coming out of your head unit for the remote turn on and not power antenna
7/29/2012 4:20:31 PM •
XO Vision...
Answered
on Jul 29, 2012
XOD1736
This is a problem with break wire. I too expierienced this. It is NOT a problem with radio. You need to ground the break wire in the harness. It is a protection wire so that it knows the emergency break is on. In other words it is supposed to stop you from watching movies while driving. Grounding the wire disbales the feature thinking the break is on. If you want to use the safety feature properly it should be connected to the emergency break switch that is grounded when pulled up or on.
10/17/2011 8:35:55 PM •
XO Vision...
Answered
on Oct 17, 2011
"WARNING STOP WATCH WATCH VIDEO" and no sound
Follow the following steps to overcome this problem:
- Locate the "Brake" wire (usually the pink wire).
- Connect the "Brake" wire to a negative point, e.g. body of vehicle.
- Test by playing a DVD and your problems have been solved.
10/17/2011 7:41:48 PM •
XO Vision...
Answered
on Oct 17, 2011
Problem w/ touch sceen
yes it can be faulty ribbon cable, slack connection on the cable that attach to the touch screen.
I had that problem too, actually it was slack connection on touch screen
7/5/2011 6:16:26 PM •
XO Vision...
Answered
on Jul 05, 2011
