20 Most Recent
ASUS VW222U Monitor Questions & Answers
Horizontal lines on ASUS laptop screen
HI friend
If you have External Monitor check by connecting it
if you get
display on external monitor without line it means Display screen is Bad,
if Line appears on external display as well then there is Motherboard problem Please contact Your nearest service centre for Service.
Enable overdrive on screen
у меня на екране показывает Enable over driver (Yes no) ничего немогу зделать показывает по центру. Ето сообщение невозможно выключить. помогите кто сможет.
Windows 7 ultimete 64-x
nvidia Geforse 9600GT
intel core2 duo CPU E8200
2.66GHz
2.67GHz
RAM 4,0GB
[URL=http://fastpic.ru/][IMG]http://i13.fastpic.ru/big/2011/0109/69/6b3db7b0dbe4318765b52ad3b6a5ca69.jpg[/IMG][/URL]
Hi i have a problem
I believe you will need to open the case up to repair this... I recommend taking it to a repair shop to fix it.
I have 4 monitors 2
You will have to enable them through ATI's Catalyst Control Center software. Get the latest at amd.ati.com
Once you have installed the CCC, you will need to navigate to "Desktops and Displays" then create a new "Eyefinity Group"
The software should automatically detect the monitors and let you configure them however you desire.
*NOTE: To run 4 Screen Eyefinity, you will have to have two of the monitors connected with ACTIVE display port adapters.
There is a pop up on my screen that sais: "Enable OverDrive"
hello... after a day with the same problem... I finished my calm... and slapped with my fingers in the buttons of my monitor... and they started to work... I think that was a very stupid solution, but in my case it work fine! hope that fix your problem too :)
