20 Most Recent Mitsubishi WD-60735 Projection Television Questions & Answers
Good Day,
It sounds like the TV has a bad COLOR WHEEL Part # 938P137010. 99.9% sure this will solve your noise.
Good Luck, Big Irish.
Mitsubishi... | Answered on Nov 19, 2016
it used to be an issue from when older projection TV's were fluid cooled , but modern lcd projection tv (like this one) don't have any issues in cold weather other than it will take several minutes till picture comes into focus in extreme cold weather , but should not give any long lasting effects once its up at operating temps one thing though don't move it once its hot during cold weather or lamp light source will go out , one thing that will cause long term problems is if its subjected to high humidity (water) this causes all sort of corrosion problems in sets of all types
Mitsubishi... | Answered on Oct 15, 2016
A common issue and it may be your problem is dust and dirt inside the unit---the set intakes air from the front and exhausts it out the rear==I have seen several of these sets where removing rear cover and taking stthe set outside and blowing it with a air compressor clears the issue.
Fans and other critical items that get clogged or coated with a moderate amount of dust will cause this issue.
Mitsubishi... | Answered on Mar 05, 2016
  • replace bulb
Mitsubishi... | Answered on Feb 02, 2016
DLP chip needs replaced...about $200 for the chip and replace yourself. YouTube has videos on how to replace
Mitsubishi... | Answered on Jan 01, 2016
You can use compressed air but it will leave the dust inside. If you remove the bezel you can take the front face off and clean it that way. I would not recommend using cleaning solvents to clean the screen use a dry cloth. The screws are on the back side along the edge of screen.
Mitsubishi... | Answered on Oct 18, 2015
It will be the LAMP the only last between 5,000 to 8,000 playing hours so if your not watching TV turn it off.
Mitsubishi... | Answered on Jun 22, 2015
This set has aside from the recessed front reset two more done with the Mitsubishi remote.
The soft reset "should" be with set on Menu, 1,2,3, enter
The hard reset requires a 4 digit number code and is based on model number and also done with the Mitsubishi remote--try to see if soft reset works at all on this model.
Mitsubishi... | Answered on Jun 20, 2015
Mitsubishi WD-60735 Projection Television Logo
338 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
WD Mitsubishi
  • WD Mitsubishi
Most Popular Question
tv comes picture shuts down red blinking
  • Televison & Video
