20 Most Recent
SonicWALL TZ 180 (01-SSC-6550) Firewall Questions & Answers
My network quit working, I logged in and found
you should conform whether DHCP working properly or not or may be firewall doing block DHCP request pls check then though if you are not able to solve this issue reply me
I hope that this has been very helpful for you
Strange noise
Sounds (pun intended) like one of the cooling-fans has worn-out bearings, and is "screeching", just before it totally freezes-up, and dies, and causes your SonicWall to overheat.
7/29/2014 3:53:48 AM •
SonicWALL...
Answered
on Jul 29, 2014
UPNP over sonicwall
For "security" reasons, you should not all UPNP traffic from "outside" of your network to enter your "internal" network. Block it.
7/29/2014 2:58:47 AM •
SonicWALL...
Answered
on Jul 29, 2014
Remove pc performer from my computer
Hi you can remove the PC Perfomer using the software Ccleaner.
CCleaner 4 09 4471
select tools and uninstall the PC Performer, if it doesn't uninstall then select delete entry. Also Ccleaner makes your computer faster by removing temporary files/cleaning registry. Hope this helps.
5/30/2014 6:08:17 AM •
SonicWALL...
Answered
on May 30, 2014
Hack the sonic wall
Hacking is a broad term and there are many attack vectors which you can use. If you do not truly understand that then you will not be cracking a firewall. You need a method of attack, recon it and search the vulnerabilities.
4/28/2014 7:07:17 PM •
SonicWALL...
Answered
on Apr 28, 2014
Get bsnl internet settings sony xperia
The high-level answer is to get the login parameters and internal IP for the Sonicwall, get the Internet parameters for your new ISP, and then log into the Sonicwall device, go to Networking-> Interfaces, and configure the WAN adapter with those settings.
1/31/2014 2:27:29 PM •
SonicWALL...
Answered
on Jan 31, 2014
