20 Most Recent
DFI LANPARTY DK P35-T2RS LGA 775 Intel P35 ATX Intel Motherboard Questions & Answers
Where are the drivers?
Here is the website and the driver pages link. The actual drivers are on the second and third page. They are not listed by OS, so you may have to download them first to find out what they are for. Don't expect to find drivers for WIN 7/8/8.1/10. This motherboard was made when XP was the defacto OS.
Does not boot up, power supply is definitely
Please do one thing, make sure that all the wires are properly plugged into the mother-board.
As the light on the mother-board is on remove the ram(memory) from the board. If you have more than one ram(memory stick) installed then try changing their slots first and then if it doesn't work, remove them one by one and and change their slots.
It should take care of the issue. Otherwise try changing with a new ram, if it also doesn't wok then you have to check with the local technician as the problem is with the mother-board.
Hope it Helps.
Regards.
Anand Sachan
Dfi games
http://www.gamesfree.me/games/tags/dfi/
Hackers unite
That will be a very big blob of goo! Or a very large and wobbly hacker.
DFI Infinity NF4 SLI won't start
Hi steve, PC repair is trial & error. I suggest you replace the power supply or test the power supply in another PC that also uses 4 SATA drives & two PCI-E slots for starters. Two boards with the same problem is odd. You must have the CPU & fan connected, memory installed, ATA 24_pin main power plugg connected (Page 17 in manual). 4-pin_12v power connected which is located (Just to the left of DDR1 memory slot). Looking at you're board the power supply should be no less than 500w.
CPU must have thermal grease between CPU & heat sink.
Even though you have fans running & LED's on & flashing, the power supply seems to be the first item to check. Make sure the bottom of the motherboard is not touching the PC case.
Try the above & post you're finding here.
Good Luck!
Mike
